Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Xbox 360 te repareren, gebruik onze reparatiehandleidingen.
  1. Xbox 360 Teardown, Hard drive: stap 1, afbeelding 1 van 1
    • Here you would usually have a hard drive, my xbox does not. To remove it you push down the button and lift it out
  2. Xbox 360 Teardown, Removing the front cover: stap 2, afbeelding 1 van 3 Xbox 360 Teardown, Removing the front cover: stap 2, afbeelding 2 van 3 Xbox 360 Teardown, Removing the front cover: stap 2, afbeelding 3 van 3
    • You can put a flat head screw driver in between the plastic as shown and gently pry open the front
    • You can alternatively grab inside the USB port and pull the cover off
  3. Xbox 360 Teardown, Removing the bottom panel: stap 3, afbeelding 1 van 3 Xbox 360 Teardown, Removing the bottom panel: stap 3, afbeelding 2 van 3 Xbox 360 Teardown, Removing the bottom panel: stap 3, afbeelding 3 van 3
    • Use a small tool to stick in and push these pins
    • Be sure to keep pressure pulling outwards for this to come out easily
    • Make sure that you pop out the pins on both sides
  4. Xbox 360 Teardown, Removing the top plate: stap 4, afbeelding 1 van 3 Xbox 360 Teardown, Removing the top plate: stap 4, afbeelding 2 van 3 Xbox 360 Teardown, Removing the top plate: stap 4, afbeelding 3 van 3
    • Same as the bottom plate you want to push in the buttons holding this in
    • Note that there are six buttons holding this together in total so it is ok to accidentally break 1 or 2
  5. Xbox 360 Teardown, The front case: stap 5, afbeelding 1 van 2 Xbox 360 Teardown, The front case: stap 5, afbeelding 2 van 2
    • You have to evenly disconnect all four of these connectors holding it together
    • I used flat head screw driver bits to hold the connectors open
    • You have to remove a warranty sticker to open the console. Be warned, this will void your warranty.
  6. Xbox 360 Teardown, Removing the back of the casing: stap 6, afbeelding 1 van 3 Xbox 360 Teardown, Removing the back of the casing: stap 6, afbeelding 2 van 3 Xbox 360 Teardown, Removing the back of the casing: stap 6, afbeelding 3 van 3
    • You must push in these buttons (7 in total)
    • It is nearly impossible to not mess up the plastic using a screwdriver, i would recommend using an x-acto knife
    • This was one of the harder steps, you must push the button in until it clicks and then go farther still
    • Make sure you keep pressure applied outwards so that the locks do not re-engage
  7. Xbox 360 Teardown, Removing the disc drive button: stap 7, afbeelding 1 van 3 Xbox 360 Teardown, Removing the disc drive button: stap 7, afbeelding 2 van 3 Xbox 360 Teardown, Removing the disc drive button: stap 7, afbeelding 3 van 3
    • To pop off this button, use the flat end of a spudger or flat-head screwdriver.
  8. Xbox 360 Teardown, Opening up to the motherboard: stap 8, afbeelding 1 van 3 Xbox 360 Teardown, Opening up to the motherboard: stap 8, afbeelding 2 van 3 Xbox 360 Teardown, Opening up to the motherboard: stap 8, afbeelding 3 van 3
    • Remove the six silver screws
    • Flip over the whole Xbox holding both the plastic and the metal, then pull off the casing
  9. Xbox 360 Teardown, Removing the disc drive: stap 9, afbeelding 1 van 3 Xbox 360 Teardown, Removing the disc drive: stap 9, afbeelding 2 van 3 Xbox 360 Teardown, Removing the disc drive: stap 9, afbeelding 3 van 3
    • Carefully remove the two connectors
    • The disc drive may have some tape in the front holding it in place, simply remove this.
  10. Xbox 360 Teardown, Opening up the fans: stap 10, afbeelding 1 van 3 Xbox 360 Teardown, Opening up the fans: stap 10, afbeelding 2 van 3 Xbox 360 Teardown, Opening up the fans: stap 10, afbeelding 3 van 3
    • To remove the fan covering, use a flat head screw driver as shown to gently pry it off
  11. Xbox 360 Teardown, Removing the fans: stap 11, afbeelding 1 van 3 Xbox 360 Teardown, Removing the fans: stap 11, afbeelding 2 van 3 Xbox 360 Teardown, Removing the fans: stap 11, afbeelding 3 van 3
    • Use a small flat head screw driver to open this locking mechanism and then gently remove the fan connector
    • Use a screw driver or spludger to pry out the fan from the casing
  12. Xbox 360 Teardown, Removing the power button: stap 12, afbeelding 1 van 3 Xbox 360 Teardown, Removing the power button: stap 12, afbeelding 2 van 3 Xbox 360 Teardown, Removing the power button: stap 12, afbeelding 3 van 3
    • To remove the "On" button simply disconnect the plastic clip
    • Remove the three black screws and pull the chip directly outwards so you do not damage the connector
  13. Xbox 360 Teardown, Removing the mother board: stap 13, afbeelding 1 van 2 Xbox 360 Teardown, Removing the mother board: stap 13, afbeelding 2 van 2
    • Remove the 9 gold screws
    • Remove the 8 black screws
    • Carefully pull out the mother board and make sure that you do not damage any connectors
  14. Xbox 360 Teardown, Displaying the main components.: stap 14, afbeelding 1 van 2 Xbox 360 Teardown, Displaying the main components.: stap 14, afbeelding 2 van 2
    • Memory card ports
    • Custom ATi Graphics Processor with 10Mb of Ram
    • 3 IBM PowerPC Cores Each Running At 3.2Ghz with 512Mb of System Ram
    • Hard drive port
    • Power port
    • HDMI and Video ports
  15. Xbox 360 Teardown, You’re finished!: stap 15, afbeelding 1 van 1
    • This is it. Follow these steps in reverse to re-assemble your Xbox 360 system!
Michael
510 Reputatie
1 Handleiding geschreven
11 opmerkingen
Please comment if you have any suggestions or help so that I can be sure to update this, or do a better job in the future.
Michael - Antwoord
Your method is very offensive and not recommended when you wont damage the case of your Xbox 360.
TheSupport - Antwoord
Up yours it obviously helped 3.1 thousand people. Being as you have zero guides and close to no reputation, maybe you should try it. But your input is valued, so thank you.
Michael -
$@$*-hot reply - like it!!!
lawsewilliams - Antwoord
this was helpful
tostypinapple - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 91
Afgelopen 30 dagen: 390
Altijd: 28,964
