Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Wiko Pulp 4G Phone te repareren, gebruik onze reparatiehandleidingen.
  1. Wiko Pulp 4G Teardown, Wiko Pulp 4G Teardown: stap 1, afbeelding 1 van 3 Wiko Pulp 4G Teardown, Wiko Pulp 4G Teardown: stap 1, afbeelding 2 van 3 Wiko Pulp 4G Teardown, Wiko Pulp 4G Teardown: stap 1, afbeelding 3 van 3
    • So, what do we have here? This affordable smartphone offers some impressive specs at first glance:
    • Qualcomm® Snapdragon Quad-Core with 1.2 GHz
    • 2 GB RAM and 16 GB ROM (and additional Micro SD for up to 64 GB)
    • 5 inch IPS Display with 1280x720 pixels
    • 13 megapixels camera with 1080P video recording at 30 fps
    • USB OTG connection, a standard 3.5mm headphone jack, and an integrated Stereo FM Radio receiver
    • Android​ 5.1 Lollipop
    • Dual sim: 1 micro SIM + 1 nano SIM
  2. Wiko Pulp 4G Teardown: stap 2, afbeelding 1 van 3 Wiko Pulp 4G Teardown: stap 2, afbeelding 2 van 3 Wiko Pulp 4G Teardown: stap 2, afbeelding 3 van 3
    • We line a shift5.1 (left) up next to our Wiko Pulp 4G and see some similarities in their designs.
    • With the Wiko's official length measuring 143.9 mm from top to bottom, it is only 0.1 mm shorter than the shift5.1.
    • We played a very simple game of smart phone Jenga with the phones to see how their widths and thickness...stack up to each other.
    • Both have the same width: 72 mm. The Pulp4G, on top, is 8.8 mm thick, yet it appears thinner than the 7 mm of the shift 5.1, possibly due to its curved edges.
    • The back cover has a different look but is the same kind of snap off.
  3. Wiko Pulp 4G Teardown: stap 3, afbeelding 1 van 2 Wiko Pulp 4G Teardown: stap 3, afbeelding 2 van 2
    • Starting with the easily removable back cover we begin our journey towards the inside of this smartphone.
  4. Wiko Pulp 4G Teardown: stap 4, afbeelding 1 van 3 Wiko Pulp 4G Teardown: stap 4, afbeelding 2 van 3 Wiko Pulp 4G Teardown: stap 4, afbeelding 3 van 3
    • The user-removable Li-Po battery pops out with the move of a finger.
    • With 9.5 Wh (2500 mAh @ 3.8 V), it finds its place ahead of the iPhone 6 with 6.91 Wh (1810 mAh @ 3.82 V) and close behind the Galaxy S5 with 10.7 Wh (2800 mAh @ 3.85 V).
  5. Wiko Pulp 4G Teardown: stap 5, afbeelding 1 van 3 Wiko Pulp 4G Teardown: stap 5, afbeelding 2 van 3 Wiko Pulp 4G Teardown: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Phillips #000 Screwdriver
    $5.49
    Koop
    • The mid frame is held in place by eleven Phillips screws.
    • Having removed those screws we use our trusty plastic opening tool to pry away the mid frame.
  6. Wiko Pulp 4G Teardown: stap 6, afbeelding 1 van 2 Wiko Pulp 4G Teardown: stap 6, afbeelding 2 van 2
    • The only thing that remains inside the midframe is the rear facing loud speaker.
    • We are happy to see that it connects to the motherboard via spring contacts, allowing easy replacements in the future.
  7. Wiko Pulp 4G Teardown: stap 7, afbeelding 1 van 3 Wiko Pulp 4G Teardown: stap 7, afbeelding 2 van 3 Wiko Pulp 4G Teardown: stap 7, afbeelding 3 van 3
    • On the back of the display assembly we find the motherboard at the top section.
    • We take a moment to rejoice when we see all those ZIF connectors and bracket-covered press connectors. Then, start swiftly unlocking and unplugging them one by one.
  8. Wiko Pulp 4G Teardown: stap 8, afbeelding 1 van 3 Wiko Pulp 4G Teardown: stap 8, afbeelding 2 van 3 Wiko Pulp 4G Teardown: stap 8, afbeelding 3 van 3
    • First thing to come out is the small front facing camera which offers 5 megapixels.
    • Second in line is the big brother for the rear facing side which provides 13 megapixels for full HD video recording.
  9. Wiko Pulp 4G Teardown: stap 9, afbeelding 1 van 2 Wiko Pulp 4G Teardown: stap 9, afbeelding 2 van 2
    • One of the display cables still clings to the motherboard but can be peeled off easily.
    • Just two more Phillips screws to unscrew and we can take the board out for a close inspection.
  10. Wiko Pulp 4G Teardown: stap 10, afbeelding 1 van 2 Wiko Pulp 4G Teardown: stap 10, afbeelding 2 van 2
  11. Wiko Pulp 4G Teardown: stap 11, afbeelding 1 van 2 Wiko Pulp 4G Teardown: stap 11, afbeelding 2 van 2
    • IC Identification, Continued:
    • Qorvo RF1496A SP12T Antenna Switch
    • Skyworks SKY13416-485LF SP6T Antenna Switch
    • Texas Instruments TPD1S414 USB Charger OVP Switch w/ ESD Protection
    • ON Semiconductor NCP114AMX310T 300 mA/3.1 V LDO Regulator
    • Silergy DC-DC Converters
    • Likely Maxscend GNSS LNA
  12. Wiko Pulp 4G Teardown: stap 12, afbeelding 1 van 2 Wiko Pulp 4G Teardown: stap 12, afbeelding 2 van 2
    • Sensor identification:
    • TDK Invensense MPU-6881 3-Axis Accelerometer/Gyroscope
    • AKM Semiconductor AK09911 3-Axis Electronic Compass
    • Rohm BU52021HFV Hall Sensor
    • Proximity Sensor
  13. Wiko Pulp 4G Teardown: stap 13, afbeelding 1 van 3 Wiko Pulp 4G Teardown: stap 13, afbeelding 2 van 3 Wiko Pulp 4G Teardown: stap 13, afbeelding 3 van 3
    • Behind the mother board we remove a rubber gasket that goes around the headphone jack and holds the lens for the LED flash.
    • Last part at the top section is the earpiece speaker.
  14. Wiko Pulp 4G Teardown: stap 14, afbeelding 1 van 3 Wiko Pulp 4G Teardown: stap 14, afbeelding 2 van 3 Wiko Pulp 4G Teardown: stap 14, afbeelding 3 van 3
    • At the bottom of the display assembly we find a daughter board with some components.
    • First we disconnect the cable coming from the motherboard and pry out the vibrator.
    • Next we peel off a small connector plate and disconnect the antenna cable.
    • Now we are ready to carefully pry out the daughter board itself which is glued in with some double sided tape.
  15. Wiko Pulp 4G Teardown: stap 15, afbeelding 1 van 2 Wiko Pulp 4G Teardown: stap 15, afbeelding 2 van 2
    • Being able to detach the daughter board completely from the cable (and therefore from the mother board) is a big advantage over the shift5.1.
    • On the other hand, all of the components are soldered to the board, which makes repairing them individually a bit trickier.
    • USB port
    • Vibrator
    • Microphone
  16. Wiko Pulp 4G Teardown: stap 16, afbeelding 1 van 2 Wiko Pulp 4G Teardown: stap 16, afbeelding 2 van 2
    • Speaking of the connection cable, we peel off the big sticker and find the second display cable running underneath and directly into the display itself.
    • With the sticker gone it is possible to also take away the power and volume buttons.
    • We stop here, leaving the connector cable in place.
  17. Wiko Pulp 4G Teardown: stap 17, afbeelding 1 van 1
    • We take a moment and sum up what we've discovered.
  18. Laatste gedachten
    • Replacing the battery is easy as pie with the swappable back cover.
    • This phone doesn't use excessive glue nor proprietary screws—we found only Phillips throughout the entirety.
    • Most of the components can be replaced separately.
    • The motherboard and daughterboard are connected via a detachable cable.
    • Unfortunately, the components on the daughterboard are soldered on, making a repair on an individual component difficult.
    Repareerbaarheidsscore
    7
    Repareerbaarheid 7 op 10
    (10 is gemakkelijkst te repareren)
Tobias Isakeit
117.296 Reputatie
188 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.521 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 10,311
