Inleiding
This guide will help you to completely disassemble your phone in order to perform other repairs.
Wat je nodig hebt
Uniden EXP371 900 MHz Cordless Phone.
900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
Once you have removed the five screws you may lift the motherboard off of the front case.
At this point you may also remove the dial pad. It simply lifts off.
You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
The whole phone is now disassembled at this point.
