Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Gereedschappen die in deze demontage worden gebruikt
Inleiding
This guide will help you to completely disassemble your phone in order to perform other repairs.
Deze demontage is geen reparatiehandleiding. Om je Uniden EXP 371 te repareren, gebruik onze reparatiehandleidingen.
  1. Uniden EXP371 900 MHz Cordless Phone.
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone. Next remove the battery by pulling on the connector.
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  4. Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver. Now remove the top portion of the case from the bottom.  This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  5. Your next step is to remove the five screws holding down the motherboard.  Use the PH1 philips screwdriver. Once you have removed the five screws you may lift the motherboard off of the front case. At this point you may also remove the dial pad. It simply lifts off.
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
Tim Reimer
164 Reputatie
3 handleidingen geschreven
Één commentaar
this guide is poorly written, please delete or improve it.
Walker Quine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 4,443
