Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Toshiba Satellite M45 te repareren, gebruik onze reparatiehandleidingen.
  1. Toshiba Satellite M45 Teardown, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, Battery: stap 1, afbeelding 3 van 3
    • Make sure device is off and power supply is disconnected.
    • Flip the laptop to the bottom side.
    • Locate and slide the two battery locks to disconnect the battery.
    • Remove the battery by sliding it out away from the computer (horizontal with the casing).
  2. Toshiba Satellite M45 Teardown, Optical Drive: stap 2, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, Optical Drive: stap 2, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, Optical Drive: stap 2, afbeelding 3 van 3
    • Use the #1 Phillips head screwdriver remove the Optical Drive screw.
    • Use the blue iFixit Opening Tool to pry the Optical Drive out of the slot from the side of the casing.
    • Use your hands to pull the rest of the Optical Drive out.
  3. Toshiba Satellite M45 Teardown, RAM: stap 3, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, RAM: stap 3, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, RAM: stap 3, afbeelding 3 van 3
    • Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
    • Then, use a the blue iFixit Opening Tool to pry the cover panel off.
    • Push on to the RAM tabs to disconnect the RAM form the device.
    • The RAM will pop off from the socket. Gently pull the RAM out of the socket.
  4. Toshiba Satellite M45 Teardown, Hard Drive: stap 4, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, Hard Drive: stap 4, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, Hard Drive: stap 4, afbeelding 3 van 3
    • Use the #1 Phillips head screwdriver as to remove the hard drive screw.
    • Use the blue iFixit Opening Tool to pry the cover off.
    • Use the plastic flap to pull the hard drive out of its slot.
  5. Toshiba Satellite M45 Teardown, Wi-Fi Card: stap 5, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, Wi-Fi Card: stap 5, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, Wi-Fi Card: stap 5, afbeelding 3 van 3
    • Use the #1 Phillips head screwdriver to unscrew the panel.
    • Disconnect the black and white wires.
    • Push on the tabs to disconnect the Wi-Fi card.
    • Use the blue iFixit Opening Tool to pull the Wi-Fi Card out.
  6. Toshiba Satellite M45 Teardown, Display: stap 6, afbeelding 1 van 1
    • Remove the 2-3 pieces of black electrical tape covering the black-and-white antenna cable.
    • Close the display, flip the laptop over, and disconnect the black-and-white antenna cables from the Wi-Fi card.
    • Flip the laptop back over and open the display.
  7. Toshiba Satellite M45 Teardown: stap 7, afbeelding 1 van 3 Toshiba Satellite M45 Teardown: stap 7, afbeelding 2 van 3 Toshiba Satellite M45 Teardown: stap 7, afbeelding 3 van 3
    • Remove the two Phillips #1 screws securing the display hinges.
    • It is recommended to keep the screws in a small cup so that you don't lose them.
    • Remove the four Phillips #1 screws on the back of the laptop.
  8. Toshiba Satellite M45 Teardown: stap 8, afbeelding 1 van 1
    • Gently pull up on the display's video connector to remove it.
    • Remove the black-and-white antenna cable from the groove.
    • Your display can now be removed.
  9. Toshiba Satellite M45 Teardown, Keyboard: stap 9, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, Keyboard: stap 9, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, Keyboard: stap 9, afbeelding 3 van 3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  10. Toshiba Satellite M45 Teardown: stap 10, afbeelding 1 van 3 Toshiba Satellite M45 Teardown: stap 10, afbeelding 2 van 3 Toshiba Satellite M45 Teardown: stap 10, afbeelding 3 van 3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  11. Toshiba Satellite M45 Teardown, Speakers: stap 11, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, Speakers: stap 11, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, Speakers: stap 11, afbeelding 3 van 3
    • Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires.
    • Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
  12. Toshiba Satellite M45 Teardown: stap 12, afbeelding 1 van 2 Toshiba Satellite M45 Teardown: stap 12, afbeelding 2 van 2
    • To remove the left speaker follow the motherboard repair guide to complete this step to keep this guide concise.
    • Reverse the order after installing the new speakers.
  13. Toshiba Satellite M45 Teardown, Cooling Unit: stap 13, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, Cooling Unit: stap 13, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, Cooling Unit: stap 13, afbeelding 3 van 3
    • Remove the cover from the cooling unit.
  14. Toshiba Satellite M45 Teardown: stap 14, afbeelding 1 van 2 Toshiba Satellite M45 Teardown: stap 14, afbeelding 2 van 2
    • Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
  15. Toshiba Satellite M45 Teardown: stap 15, afbeelding 1 van 1
    • Follow the tear-down guide until you have access to the fan unit on the motherboard.
  16. Toshiba Satellite M45 Teardown: stap 16, afbeelding 1 van 3 Toshiba Satellite M45 Teardown: stap 16, afbeelding 2 van 3 Toshiba Satellite M45 Teardown: stap 16, afbeelding 3 van 3
    • Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
  17. Toshiba Satellite M45 Teardown, Motherboard: stap 17, afbeelding 1 van 3 Toshiba Satellite M45 Teardown, Motherboard: stap 17, afbeelding 2 van 3 Toshiba Satellite M45 Teardown, Motherboard: stap 17, afbeelding 3 van 3
    • Disconnect the video cable, then slowly and firmly pull the video cable upwards.
    • Disconnect the brown ribbon located in the middle area of the laptop.
    • Disconnect the two white ribbons located in the bottom left of the laptop.
    • Firmly pull out the two white ribbons.
  18. Toshiba Satellite M45 Teardown: stap 18, afbeelding 1 van 2 Toshiba Satellite M45 Teardown: stap 18, afbeelding 2 van 2
    • Use the Phillips #00 Screwdriver to unscrew all the screws.
    • Unscrew three additional screws through the three holes on the optical drive.
  19. Toshiba Satellite M45 Teardown: stap 19, afbeelding 1 van 3 Toshiba Satellite M45 Teardown: stap 19, afbeelding 2 van 3 Toshiba Satellite M45 Teardown: stap 19, afbeelding 3 van 3
    • Turn the laptop upside down.
    • Use the blue iFixit Opening Tool to slowly pry the case upward.
    • Remove the white ribbon
    • Make sure to completely remove the white ribbon and set it to the right side of the motherboard. and not on top of the motherboard.
  20. Toshiba Satellite M45 Teardown: stap 20, afbeelding 1 van 2 Toshiba Satellite M45 Teardown: stap 20, afbeelding 2 van 2
    • Lift up the motherboard.
    • Be careful not to rip out small components on the motherboard. Carefully remove the motherboard.
  21. Toshiba Satellite M45 Teardown, Toshiba Satellite M45 Teardown: stap 21, afbeelding 1 van 1
    • Congratulations, your computer has been completely dismantled!
    • Now, reverse the steps to reassemble.
Bobby Davis
154 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 4-1, Calaway Spring 2014 Lid van UMass Dartmouth, Team 4-1, Calaway Spring 2014
UMASSD-CALAWAY-S14S4G1
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 2,527
