Ga door naar hoofdinhoud
Deze demontage is aan de gang – Herlaad regelmatig om de laatste wijzigingen te zien!
Wat je nodig hebt
  1. Toshiba Click 2 Pro P35W-B3226 Teardown, Back Cover: stap 1, afbeelding 1 van 2 Toshiba Click 2 Pro P35W-B3226 Teardown, Back Cover: stap 1, afbeelding 2 van 2
    • After this procedure there seemed to be more back light bleed on my tablet. Not sure if it was there before so be careful.
    • Remove the tablet from the dock.
    • Find the best place to insert your plastic pry tool (I used the Micro-SD slot). Carefully go around the perimeter of the tablet and unclip the back cover.
    • Take note off all the clips. The back cover is held in place with a ton of these all around.
  2. Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 1: stap 2, afbeelding 1 van 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 1: stap 2, afbeelding 2 van 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 1: stap 2, afbeelding 3 van 3
    • Once you have the back cover off you are free to replace what you'd like.
    • Msata SSD Part #MZMTE128HMGR-0000
    • M.2 2230 WiFi Model #7260NGW
  3. Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 2: stap 3, afbeelding 1 van 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 2: stap 3, afbeelding 2 van 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Internals Part 2: stap 3, afbeelding 3 van 3
    • Battery Model #PA5190U-1BRS
    • Motherboard Part #DAOZC1MBADO REV:D
    • Capacitive button/dock board Part #3TCZ1T80000
    • Re-assembly in reverse order.
  4. Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Disassembly: stap 4, afbeelding 1 van 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Disassembly: stap 4, afbeelding 2 van 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Disassembly: stap 4, afbeelding 3 van 3
    • With the keyboard separated remove all the screws in the bottom. The top 4 screws are longer then the bottom 6.
    • Keyboard back cover Part #ZYE35CZ1BA0100140810-01 REV:3A
    • Keyboard boards and weights.
  5. Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Parts: stap 5, afbeelding 1 van 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Parts: stap 5, afbeelding 2 van 3 Toshiba Click 2 Pro P35W-B3226 Teardown, Keyboard Parts: stap 5, afbeelding 3 van 3
    • The keyboard dock board. Looks like there is a way to add a second HDD/SSD here but the connector is not soldered on.
    • Keyboard board Part #CZ1D30E51001CC
    • Mouse board, left-hand weight, front LED board.
Sasa Macura
177 Reputatie
2 handleidingen geschreven
3 opmerkingen
lindas fotos pero no hay un video que muestre como demontar la tapa.
ximena - Antwoord
muy ilustrativas las imagenes.. tendras algunas donde se vea el mecanismo del teclado donde sujeta a la pantalla ?
carlos - Antwoord
i need keyboard for this lap how i can get it
Hussien Mahmoud - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 7,475
