Wat je nodig hebt
Unscrew the 4 screws attaching the bottom cover to the top.
At the back of the router, pull the bottom cover from the top cover.
And slide/push the cover to the front, releasing it from the frontside retaining clip.
Flip the circuit board out of the top cover.
Detach antenna cable from the circuit board.
Use the pliers to squeeze the clip holding the antenna in, and pull the antenna from the housing.
Broadcom BCM6348KPBG
Broadcom BCM5325EKQMG
Infineon PEB 3332 HT V2.1
Broadcom BCM4318KFBG
Spansion S29GL032A90TFIR40
