Wat je nodig hebt
Using the Phillips head screwdriver, remove the 6 screws
Pry the back panel open with the flathead
Remove the two screws holding the battery down
Take off the metal cover
Remove the battery
Use the Phillips head screwdriver to remove the two screws securing the LCD to the plastic chassis
With the flathead, wedge out the LCD screen without disconnecting the internal wiring
This is the furthest that the calculator can be torn down without destroying the calculator beyond repair
Reassemble the calculator, placing the LCD screen, battery, back panel, and screws in the proper position
After the calculator is reassembled, the calculator truly works as it did before the teardown
