Wat je nodig hebt
Remove the 2 rubber feet covering up the screws holding the top cover.
Unscrew the T10 screws.
Use the spudger to pry open the top cover and remove it.
It this point, the board is held in place by the case itself.
Bend the front side of the case outward, allowing the board to move up.
With the front side removed from the case, slide the backside of the board from the case as well
Two parts are still attached to the case.
Use the spudger to separate the glued on part from the case and repeat on the other side.
Remove the lid of the cable case.
View the board
Bothhand GS5014LF
STMicroelectronics NAND512W3A2CN6
Unscrew the WiFi module.
