Ga door naar hoofdinhoud
Wat je nodig hebt
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je Surface Go 2 te repareren, gebruik onze reparatiehandleidingen.
    Laatste gedachten
    • This version of the Surface Go is significantly easier to open thanks to the new display adhesive and redesigned interior shields.
    • The use of only one type of screw simplifies repair.
    • The lack of modularity, especially on high-wear ports, makes repairs unnecessarily expensive.
    • Replacement of any part requires removal of the display assembly, an easy (and expensive) part to damage.
    Repareerbaarheidsscore
    3
    Repareerbaarheid 3 op 10
    (10 is gemakkelijkst te repareren)
7 opmerkingen
A big part of the Surface’s thermal solution is the aluminum backshell. If they added thermal pads between the back of the CPU and PMIC area of the PCB and the case, it would definitely be a nice touch.
Ethan Zuo - Antwoord
We’ve always got modders to do that.
Strumajen -
Does anyone knows if the battery for the surface go 1 is compatible with the surface go 2 and vice versa?
Odysseus - Antwoord
Is the LTE modem removable/swapable?
Dan - Antwoord
Unfortunately it is soldered to the motherboard
Josh *thegadget* Hymer -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 109
Afgelopen 30 dagen: 475
Altijd: 29,447
