Ga door naar hoofdinhoud
Deze demontage is aan de gang – Herlaad regelmatig om de laatste wijzigingen te zien!
Wat je nodig hebt
    • Be cautious when using the iOpener for opening the adhesive on the cheese packaging.
    • Inspect the string cheese packaging. You should see a perforated corner that you can stick the tip of your spudger into.
    • Once you put the tip of the spudger into the plastic pull the corner with your other hand, guiding the spudger along as you peel back the packaging.
    • We're in to the GOOD stuff,
    • Pull up on the cheese to get it unstuck from the adhesive
    • Then peal the last bits of adhesive away
    • YOU CANT PUT IT BACK TOGETHER
Ben Capehart
6.264 Reputatie
18 handleidingen geschreven
Master Techs Lid van Master Techs
Community
312 Leden
1.330 handleidingen geschreven
19 opmerkingen
@beanman56
This it a great teardown >:-D
Can we see a teardown on a strawberry?
HelloMacOS - Antwoord
@hellomacos - Help if you want
Ben Capehart -
Sure ,what do you want me to do?
HelloMacOS -
@hellomacos - Idk do what you want X-D
Ben Capehart -
@hellomacos - Will Do! >:-D
[ongeldige handleidingslink]
Ben Capehart - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 113
