Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Steam Controller te repareren, gebruik onze reparatiehandleidingen.
  1. Steam Controller Teardown, Steam Controller Teardown: stap 1, afbeelding 1 van 3 Steam Controller Teardown, Steam Controller Teardown: stap 1, afbeelding 2 van 3 Steam Controller Teardown, Steam Controller Teardown: stap 1, afbeelding 3 van 3
    • We open the valve and the specs come pouring out:
    • High-definition haptic feedback
    • Dual trackpads
    • USB 2.0 via Micro-USB port
    • 6-axis combination gyroscope-accelerometer sensor
    • Dual-stage digital triggers with 10° of travel, magnetic flux sensor, and tactile switch
    • Up to 80 hours of gameplay from a pair of removable AA batteries
    • 5 meters of wireless communication range
  2. Steam Controller Teardown: stap 2, afbeelding 1 van 3 Steam Controller Teardown: stap 2, afbeelding 2 van 3 Steam Controller Teardown: stap 2, afbeelding 3 van 3
    • For comparison purposes: an Xbox One controller next to the Steam Controller.
    • Both controllers share the same AB-XY button layout, but Valve's offering has a substantially larger footprint thanks to its pair of capacitive touchpads.
    • The rear cover snaps off with no tools required to reveal the model number: 1001.
  3. Steam Controller Teardown: stap 3, afbeelding 1 van 2 Steam Controller Teardown: stap 3, afbeelding 2 van 2
    • After rooting around the battery compartment, we punch through the sticker on the back to find three T6 Torx screws.
    • With the rear housing removed, we get our first look inside the controller as the glossy black exterior gives way to the mossy green PCB interior.
    • So far we've only used our hands and a screwdriver, but we're already in—this controller's already scoring points in our book.
  4. Steam Controller Teardown: stap 4, afbeelding 1 van 3 Steam Controller Teardown: stap 4, afbeelding 2 van 3 Steam Controller Teardown: stap 4, afbeelding 3 van 3
    • Underneath the rear casing, we find a couple of snazzy battery eject levers—something we haven't seen in other controllers.
    • Faster battery replacements mean less time not playing video games. Word.
    • While battery eject levers are nice, what we're actually interested in is Valve's decision to abstain from using an integrated battery.
    • This design choice eliminates a commonly-failing component to extend the Steam Controller's lifetime, and gives users a choice: disposable or rechargeable batteries. The future of the planet is (literally) in your hands.
  5. Steam Controller Teardown: stap 5, afbeelding 1 van 3 Steam Controller Teardown: stap 5, afbeelding 2 van 3 Steam Controller Teardown: stap 5, afbeelding 3 van 3
    • It's a trap! Lifting the motherboard out of its housing reveals a couple hidden ribbon cables connecting the touchpads to the underside of the board.
    • Repairer beware: removing the motherboard without dispatching these cables will greatly increase your repair woes.
    • We're never fans of treacherous cables like these, but this is hardly the worst we've seen.
    • Moving right along, we disconnect the ribbon cables with a firm tug, freeing the upper assembly for closer inspection and giving us a glimpse at the inner workings of the touchpads.
  6. Steam Controller Teardown: stap 6, afbeelding 1 van 3 Steam Controller Teardown: stap 6, afbeelding 2 van 3 Steam Controller Teardown: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Pro Tech Toolkit
    $74.95
    Koop
    • We finally break out our favorite tools to bust the touchpad out from behind its bracket bars. This time, we're using a plastic opening tool from our all-new Pro Tech Toolkit.
    • The ribbon cable plugs into a socket on the touchpad daughterboard and is soldered to the haptic feedback actuators, adding some redundancy and durability to the touchpad module.
    • The whole assembly is a touchpad solution from Cirque, likely the GlidePoint TM040040.
    • The brains of the operation is a Cirque 1CA027 companion MCU.
    • Also hiding on the daughterboard we find one of our least favorite things: glue. Those two black globs are mounds of adhesive, securing the touchpad to its bracket.
    • Happily, this is the only adhesive we encountered in this device, and neutralizing it didn't get too messy.
  7. Steam Controller Teardown: stap 7, afbeelding 1 van 3 Steam Controller Teardown: stap 7, afbeelding 2 van 3 Steam Controller Teardown: stap 7, afbeelding 3 van 3
    • We deftly dispatch a few more screws and the dual-stage triggers come along for a ride.
    • Much to our surprise they simply slot into the motherboard. No adhesive nor mechanical tricks here!
    • The dual-stage trigger can be broken down into two stages:
    • The first is the smooth motion of the trigger when initially pressed. The magnetic flux sensor measures the position and speed of the trigger based on a time-varying flux.
    • The second part is the click at the end where the trigger physically presses a button on the motherboard.
    • Boom, headshot.
  8. Steam Controller Teardown: stap 8, afbeelding 1 van 2 Steam Controller Teardown: stap 8, afbeelding 2 van 2
    • The motherboard is a fiberglass plane home to a smattering of circuit elements. We do our due diligence and identify:
    • NXP LPC11U37F 32-bit ARM Cortex-M0 microcontroller
    • Nordic Semiconductor nRF51822 Bluetooth Smart and 2.4GHz proprietary SoC
    • Invensense MPU-6500 Six-Axis (Gyro + Accelerometer) MEMS MotionTracking device
    • Allegro Microelectronics A1304 Hall-effect sensor
    • Texas Instruments TPS61029 200 mA / ADJ DC-DC boost converter
    • Texas Instruments TLV70230 300 mA / 3.0 V LDO regulator
  9. Steam Controller Teardown: stap 9, afbeelding 1 van 2 Steam Controller Teardown: stap 9, afbeelding 2 van 2
    • Steam Controller Repairability Score: 8 out of 10 (10 is easiest to repair)
    • The only adhesive we encountered was on the touchpads. All other mechanical connections are made with screws.
    • The Controller's relatively modular construction means replacing a single component will be a simple task.
    • While we always say screws before glue, the non-magnetic screws used in this controller are apt to get misplaced and throw a wrench into repairs.
    • The most likely-to-fail component, the thumbstick, is soldered directly to the motherboard.
Dante Mazzanti
36.177 Reputatie
26 handleidingen geschreven
39 opmerkingen
Does swapping the touchpads and reconnecting them work?
The Reloader - Antwoord
In theory yes in practice no, if you swap them you will end up with an off angle dpad. shape almost like an X Same goes for A B X Y, I tried to do the original nintendo layout but they where angled so it did not work well.
Qlum Wyrfex -
It doesn't work in theory or in practice. I mean it can work. But the effects wouldn't be what you would think. You would actually have to mod the chassis itself which takes patience and artistic craftsmanship. But it can be done just not as easy as one would think. I tried this last night. No cigar. You can always attempt a cross wire and play without the top chassis but it would be uncomfortable and exposed.
Jay Martinez -
So the thumbstick potentiometer is soldered, that's normal, but can the stick itself be replaced? My DS4 has 3rd party metal sticks.
Frank Zhao - Antwoord
I'd like to know this as well, if I get one of these I'd want to replace it with an Xbox One thumbstick if possible.
Evil Robot -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 121
Afgelopen 30 dagen: 549
Altijd: 90,168
