Gereedschappen die in deze demontage worden gebruikt
Inleiding
The Sony Ericsson s710a is a camera phone with all of the features expected of a phone in the mid '00's.
On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure.
When you lift this off, you will need to disconnect the cables from the other side using the same method as in step 5.
Again, be sure to record which port each cable was in and the orientation they were plugged into each socket.
Remove the plastic piece near the bottom of this side of the phone with the plastic opening tool. This will give you access to two additional screws.
Remember you will have to break the glue seal, but that is alright.
Remove the four visible 6mm screws and then remove the back cover.
