Inleiding
This will be an complete teardown of the camera. The camera, that was torn down had problems with the moving lens.
Wat je nodig hebt
Free up the connector under the black tape.
Disconnect the ribbon cable.
You need to pull up the brown edge of the connector to open it. (Here shown with another connector of the next step.)
Disconnect all seven remaining ribbon cables.
Disconnect these with the technique from the last step.
Simply pull these out of the connector. There are small edge at the cable to easily pull them out.
Unscrew both screws
Take out the bracket. You can then remove the bracket from the speaker.
Unscrew all three screw that are holding the bracket down.
Lift up the bracket and then the connectors.
Unscrew the three screws.
Turn the mainboard around and disconnect the last ribbon cable.
Unscrew the four screws.
Note that the two bottom screws are shorter than the others.
Frontglass holder
Frontglass, you may want to clean it, if you have disassembled it
Lens with spring. This is used to give you a sharp view into the viewfinder. The small nib is pushed in different positions by the small dial on the case to adjust the focus for your eyes
Monitor, a very small monitor. Looks much like the image sensor.
Proximity sensor for detecting your eye and therefore switching to the viewfinder.
PCB with 2 unidentified ICs (659L and 3232 615)
Backcover
Disconnect the ribbon cable to the GPS module at the top.
Unscrew the last two screws of the baseplate. Then pull the baseplate to back.
Unscrew the battery case and pull it out.
Disconnect the ribbon cable, unscrew the flash PCB from the battery case and pull them apart. Finally, the mainboard (and therefore the antenna and battery) is separated from the rest.
To remove the button panel, you have to unscrew these two screws.
When reinserting, make sure that the nib for the zoom is in the middle position. Otherwise it will zoom the whole time.
Unscrew these 4 screws to seperate the optics part from the rest of the case
Unscrew these to loosen the motor from the sensor backplate
Unscrew these 6 screws, after you have taken the optics out of the case. Note that the three motor screws where in place during the photo, but should be removed first
To be able to separate the Sensorbackplate from the rest, you have to unsolder the conenctor
Also disconnect this connector, as well as the connector on the opposite site
Finally you have the sensor with (maybe?) the auto focus lens.
The rest of the optics contains 3 tubes as well as 3 moving lenses
Unscrew the 4 screw to loosen the sprocket
Before you can remove it, you have to floss the 2 ribbon cables through the outer case. It is not easy, you have to rotate them, but it is manageable
The outer case has a gear mount and grooves for the inner tube.
This tube has the front lens integrated and is visible to the outside when the camera is turned on and zooming.
The inner tube moves all 4 lenses.
This groove moves the tube with the front lens.
The three inner grooves moves the image stabilisation, the shutter and an additional lens.
This nip interacts with the grooves in the outer tube.
Unscrew all 5 screws to remove the rod holder. Then you can separate all three optics groups.
This is a moving lens with no other purpose
This is the shutter and aperture module. It also integrates some lenses.
This is the image stabilisator, which contains two coils and magnets.
The shutter and aperture is combined into one assembly.
The shutter seems to be actuated by a magnet.
I was able to open and close the shutter with a magnet.
These are all disassembled part. Not everything is removed from the case and disassembled entirely
