Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Solar Breeze NX Robotic Solar Pool Cleaner te repareren, gebruik onze reparatiehandleidingen.
  1. Solar Breeze NX Teardown, Carefully remove all 12 screws with 5/16" allen wrench: stap 1, afbeelding 1 van 1
    • Battery pack, desiccant and bottom of board showing T-7.7.5 firmware revision number label.
  2. Solar Breeze NX Teardown, Remove 4 screws under the board to expose the top: stap 2, afbeelding 1 van 1
    • Insert wisdom here.
  3. Solar Breeze NX Teardown, Identify the main processor: stap 3, afbeelding 1 van 1
    • ATMEL MEGA 168PA AU 1619
    • Had to use small magnifying glass to catch this photo with iPhone7plus
  4. Solar Breeze NX Teardown, Measure voltage input from the solar array: stap 4, afbeelding 1 van 1
    • 8.16 volts (the unit had sat in direct sun to recharge without use for a day prior)
  5. Solar Breeze NX Teardown, Measure output voltage 3.27v: stap 5, afbeelding 1 van 1
  6. Solar Breeze NX Teardown, Measure output voltage 8.41v: stap 6, afbeelding 1 van 1
  7. Solar Breeze NX Teardown, Measure voltage on unused part of the circuit board: stap 7, afbeelding 1 van 1
Phil
111 Reputatie
1 Handleiding geschreven
14 opmerkingen
Pretty good details, and suggestions of improvement, I also would like to have that! Do you have more pictures and details? How about the motors how good are they? how much voltage for the motors? Just curious... thanks!
Ricardo Fabar - Antwoord
They just started advertising the “NX2” on Amazon. Not sure I’ll buy another Solar Breeze. Mine only lasted about a year when the rear wheels stopped turning. Solar Breeze did send me a replacement gear set for the rear but the unit seems to always be in error mode. I’d love to figure out how to replace the main controller board with a Pi. I’m pretty sure the motors are like servos in that they give feedback. If I manually spin my rear paddle, the error light goes out and it functions as normal for another minute. So, my wish list:
1) Pi based controller
2) Wifi/BT interface
3) GPS avoidance (stop getting stuck under my dive rock
4) high wind avoidance (stop getting stuck downwind, just shutdown and wait)
5) Alert me if you are removed from the pool (theft deterent? Maybe tie into my house alarm?)
6) Repairable/replaceable parts - I hate that society has a throw-it-away attitude.
Tim - Antwoord
My unit fully charged but unable to turn on. Any advice? Thanks
Peter Lam - Antwoord
Same issue as Tim here. I think he means the front wheels. I’ve done a tear down and there are two little motors on the front wheels. The motors go out pretty easily, I replaced the unit twice while it was still under warranty. Has anyone replaced or found a replacement motor for the front wheels?
Drew 272727 - Antwoord
Hi Drew272727 - Did you ever find a replaced motor for the front wheels? Mine is fried too and chasing the motor if I can find it. Thanks.
Byron -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 49
Altijd: 6,177
