Ga door naar hoofdinhoud
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Deze demontage is geen reparatiehandleiding. Om je Apple TV 4th Generation te repareren, gebruik onze reparatiehandleidingen.
  1. Siri Remote Teardown, Siri Remote Teardown: stap 1, afbeelding 1 van 3 Siri Remote Teardown, Siri Remote Teardown: stap 1, afbeelding 2 van 3 Siri Remote Teardown, Siri Remote Teardown: stap 1, afbeelding 3 van 3
    • Insert wisdom here.
  2. Siri Remote Teardown: stap 2, afbeelding 1 van 2 Siri Remote Teardown: stap 2, afbeelding 2 van 2
anotaai
132 Reputatie
1 Handleiding geschreven
7 opmerkingen
Adhered? Screwed on? Snapped off? Wtf is this $@$*?
jvelez - Antwoord
Okey okey, it looks like the user just wanted show what was inside. The guide had been archived, but feel free to contribute whatever information you might have to help it out. We’re all about working together here.
Kelsea Weber -
It would be nice to show how to take it apart. Something spilled on my remote and I have a sticky “Menu” button, which is a pain in the A$$.
montoysc - Antwoord
The iFixit teardown goes into a bit more detail, but isn’t meant to be used as a repair guide. You should start by dipping a paper towel in some high-concentration isopropyl alcohol, and rubbing the sticky buttons on the remote. If you still need help, consider posting on our Answers forum!
Sam Goldheart -
so i have a situation where the remote dropped and the clicker will not bounce back up. after looking it seems like the hooks keeping the front from coming off are what is keeping it in place almost fused in the down state. any idea on how to possibly fix that?
smeefree - Antwoord
I’m guessing it’s the same method as the iPads and iPhones, glue all the way around, guitar picks to separate it? Probably a little heat to help the glue separate easier.
Doesnt help me much, shattered touch screen on mine. Looks like I need to just replace it.
devoh - Antwoord
Somebody tell me how to get the flex cable for the touchpad plugged back in.
Steven Machado - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 7,023
