Ga door naar hoofdinhoud
Gereedschappen die in deze demontage worden gebruikt
Inleiding
First attempt at a tear down of Seagates 3TB External Drive.
Deze demontage is geen reparatiehandleiding. Om je External Storage te repareren, gebruik onze reparatiehandleidingen.
  1. Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
    • Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
    • Once you have the end opened up, use the credit card to hold it open.
    • When you have the entire end separated, carefully pry the sides out and away along the adjoining two sides, working your way towards the end with the power jack. Save that end for last, it should lift away when you're done with the other sides.
  2. Work around the drive, ends first then the sides to open it This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart. This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart.
    • Work around the drive, ends first then the sides to open it
    • This is really challenging and I did end up breaking some of the clips. Its pretty hard to tear apart.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. Gently pull the sides slightly and the drive will lift out
    • Gently pull the sides slightly and the drive will lift out
  5. Pull the rubber screw covers off, these are mounted with a little glue and came off easily Remove all four screws with the philips screwdriver Remove all four screws with the philips screwdriver
    • Pull the rubber screw covers off, these are mounted with a little glue and came off easily
    • Remove all four screws with the philips screwdriver
  6. Slide drive out of metal caddy (do not lift) You will now have a SATA Hard Drive and the caddy separate You will now have a SATA Hard Drive and the caddy separate
    • Slide drive out of metal caddy (do not lift)
    • You will now have a SATA Hard Drive and the caddy separate
  7. From the bottom of the caddy there are two black screws With the Philips screwdriver you can remove these Pull the circuit board gently and evenly to remove it
    • From the bottom of the caddy there are two black screws
    • With the Philips screwdriver you can remove these
    • Pull the circuit board gently and evenly to remove it
Edd
511 Reputatie
2 handleidingen geschreven
if i add a different adapter that doesnt require power, will the drive still work?
sulz - Antwoord
Does anyone know what to do if the Data port does not work ?
remus lungeanu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 10
Afgelopen 7 Dagen: 73
Afgelopen 30 Dagen: 380
Altijd: 45,655
