Follow the steps in this guide in order to gain access to components found inside the device which most often require repair of replacement.
Deze demontage is geen reparatiehandleiding. Om je Sandisk Sansa m230 Series mp3 player te repareren, gebruik onze reparatiehandleidingen.
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
Be careful when prying apart the pegs: they are made of plastic and may break.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
Deze handleiding insluiten
Kies een formaat en kopieer de code hieronder om deze handleiding als een kleine widget op je website of forum in te sluiten.
Voorbeeld
