Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Samsung Galaxy J6 te repareren, gebruik onze reparatiehandleidingen.
  1. Samsung Galaxy J6 Teardown, Samsung Galaxy J6 Teardown: stap 1, afbeelding 1 van 3 Samsung Galaxy J6 Teardown, Samsung Galaxy J6 Teardown: stap 1, afbeelding 2 van 3 Samsung Galaxy J6 Teardown, Samsung Galaxy J6 Teardown: stap 1, afbeelding 3 van 3
    • With annual updates for the J3, J5 and J7 phones, the J6 has its debut this year.
    • A short spec check shows:
    • 5.6" Super AMOLED display with a resolution of 720 × 1480
    • Octa-core, 1.6 GHz Cortex-A53 Exynos 7870 processor, paired with 3 GB of RAM
    • Built-in 32 GB storage (with an additional 256 GB available via microSD card expansion)
    • 13 MP primary rear-facing camera, plus an 8 MP selfie cam
    • 149.3 × 70.2 × 8.2 mm in size, and 154 g on the scale
    • Android 8.0
  2. Samsung Galaxy J6 Teardown: stap 2, afbeelding 1 van 2 Samsung Galaxy J6 Teardown: stap 2, afbeelding 2 van 2
    • While scanning the outside for screws, we note the good ol' Micro-USB port. And a headphone jack next to it.
    • Our teardown specimen of the J6 is the Duos version, with an additional SIM and SD card slot on the side.
    • With no exterior screws to guide the way, we attack the back cover as a possible point of entry—but after some unsuccessful heating and prying, we give up and try our luck on the display.
    • After some iOpener and iSclack action, the touch panel seems to separate pretty cleanly. Is this a repairable, non-bonded display like back in the old days?
    • Sadly, no—it seems we were foiled by some extra-strong adhesive under the sAMOLED panel, which held fast while the touch panel glue gave way. End result: busted display.
    • We unplug the protected connector and remove the newly unfused display assembly to continue our journey.
    • It seems those screws we hoped to see on the outside were already used up on the midframe.
    • So we bring out our Mako Driver Kit to remove a bunch of Phillips screws …
    • … and finally pop out the midframe.
  3. Samsung Galaxy J6 Teardown: stap 5, afbeelding 1 van 2 Samsung Galaxy J6 Teardown: stap 5, afbeelding 2 van 2
    • On the other side of the midframe, we finally find the battery—glued in place.
    • After a little heat and some gentle convincing, we can push out the power pack for inspection.
    • Coming in at 11.55 Wh (3,000 mAh at 3.85 V), this is on par with last year's J5—and a bit weaker than the 2017 J7 Pro (3,600 mAh).
  4. Samsung Galaxy J6 Teardown: stap 6, afbeelding 1 van 2 Samsung Galaxy J6 Teardown: stap 6, afbeelding 2 van 2
    • Before we take a look at the motherboard, we remove the 8 MP front-facing camera at the top, and the 3.5 mm headphone jack at the bottom.
    • Much to our dismay, the USB charging port is soldered onto the motherboard—nothing to take out (or easily repair) here.
    • This unfortunately reduces the joy that the "J" in J6 stands for. But we're not done yet.
  5. Samsung Galaxy J6 Teardown: stap 7, afbeelding 1 van 2 Samsung Galaxy J6 Teardown: stap 7, afbeelding 2 van 2
    • Without further ado, we take out the motherboard …
    • … and remove the 13 MP rear camera, with its ƒ/1.9 aperture.
  6. Samsung Galaxy J6 Teardown: stap 8, afbeelding 1 van 2 Samsung Galaxy J6 Teardown: stap 8, afbeelding 2 van 2
    • On the front of the motherboard, we find:
    • Samsung KLMBG2JETD-B041 32 GB NAND Flash Memory
    • Samsung K4EHE304EC-AGCF ? 3 GB Memory layered over the Exynos 7870 chip
    • And on the back, we have:
    • Samsung Shannon 515 power management IC
    • Samsung Shannon 925 RF Tranceiver
    • Skyworks Multiband Power Amplifier SKY77656-11
    • There are also two empty areas. Maybe the same board is used for different versions of the J6 that require a different complement of chips?
  7. Samsung Galaxy J6 Teardown: stap 9, afbeelding 1 van 1
    • This completes our abbreviated teardown, with all components lined up for inspection. We'd hoped for a bit more modularity in this mid-range phone—but let's tally up the points and see how the J6 performed.
  8. Laatste gedachten
    • The only screws used are standard Phillips screws (granted, there are almost too many).
    • Display repair is prioritized, since it is the first part out—but at the cost of probably damaging it, making repairs to other components risky.
    • The battery is buried beneath the motherboard and adhered to the midframe, hindering its replacement.
    • The high-wear USB port is soldered to the motherboard, requiring a high level of skills and equipment for this all-too-common repair.
    Repareerbaarheidsscore
    4
    Repareerbaarheid 4 op 10
    (10 is gemakkelijkst te repareren)
11 opmerkingen
Where is the Simms card reader?
Teryl Davis - Antwoord
Cara, que aparelho complicado. Apliquei todos os métodos que conheço e a tela quebrou da mesma maneira que com vcs… Muito ruim! naõvou receber estes nem para troca de bateria… Alto risco de prejuízo…
lrrodriguescrt - Antwoord
Design feito para não facilitar manutenção. Se mantivessem o acesso dos parafusos pela parte traseira se conseguiria soltar a estrutura intermediária com o display ainda acoplado e depois, retirada a bateria, se removeria a cola sem destruir tudo… Design medíocre.. Ou bem planejado para ser descartável.
J6 não quer ligar
João Stefani - Antwoord
Aqui em nossa assistência, esquentamos a tela na maquina um pouco e após feito isso, começamos o trabalho da retirada do display, com a ajuda de sucção descolamos uma pequena fresta, e introduzimos pouco a pouco álcool 99,8% , e com a ajuda de uma espátula, para que possamos retirar o display sem maiores transtornos…paciência é de grande importância para abrir esse tipo de aparelho. Fazemos isso com todos os dispositivos que precisa retirar o display, e que seja amoled ( super amoled, oled, etc ) devido não correr o risco de manchar com o álcool, como acontece nos aparelhos com display LCD que mancha com o álcool que acaba penetrando nas camadas do lcd.
Rudy Ishihara - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 72
Afgelopen 30 dagen: 355
Altijd: 81,593
