Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Samsung GT-E2120 te repareren, gebruik onze reparatiehandleidingen.
  1. Samsung GT-E2120 Teardown, Samsung GT-E2120 Teardown: stap 1, afbeelding 1 van 1
    • Before you begin it's always good to ground yourself to eliminate the risk for shock.
  2. Samsung GT-E2120 Teardown: stap 2, afbeelding 1 van 2 Samsung GT-E2120 Teardown: stap 2, afbeelding 2 van 2
    • Using your thumb, press down on the back of the device in a downward motion to open the back cover.
    • Remove the battery along with the sim card and Micro-SD card.
    • This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
  3. Samsung GT-E2120 Teardown: stap 3, afbeelding 1 van 2 Samsung GT-E2120 Teardown: stap 3, afbeelding 2 van 2
    • Next, using a Philips screwdriver, remove the five screws from the back of the device.
  4. Samsung GT-E2120 Teardown: stap 4, afbeelding 1 van 3 Samsung GT-E2120 Teardown: stap 4, afbeelding 2 van 3 Samsung GT-E2120 Teardown: stap 4, afbeelding 3 van 3
    • For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
    • These clips can be found at the points marked in red.
    • Working from the top down, gently prying at the case the clips are easily dislodged.
  5. Samsung GT-E2120 Teardown: stap 5, afbeelding 1 van 2 Samsung GT-E2120 Teardown: stap 5, afbeelding 2 van 2
    • When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
    • This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
    • Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
    • Be careful so you dont damage the motherboard!
  6. Samsung GT-E2120 Teardown: stap 6, afbeelding 1 van 1
    • This images shows the two halves separated.
    • The camera located in the blue square is a VGA 640X480 resolution color camera.
  7. Samsung GT-E2120 Teardown: stap 7, afbeelding 1 van 2 Samsung GT-E2120 Teardown: stap 7, afbeelding 2 van 2
    • The microphone is carefully lifted from its bracket, and the motherboard is carefully removed.
  8. Samsung GT-E2120 Teardown: stap 8, afbeelding 1 van 1
    • Then the keyboard is simply pushed out.
    • The Phone includes a 65K CSTN color screen with a 128X128 resolution.
Michael C
410 Reputatie
1 Handleiding geschreven
OPEN Lid van OPEN
Community
84 Leden
25 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 14,094
