Ga door naar hoofdinhoud
Gereedschappen die in deze demontage worden gebruikt
Deze demontage is geen reparatiehandleiding. Om je Samsung GT-E1200I te repareren, gebruik onze reparatiehandleidingen.
  1. I have used the Jimmy for this job. Be careful when you pry with your Jimmy. It can hurt you if you use it the wrong way.
    • I have used the Jimmy for this job.
    • Be careful when you pry with your Jimmy. It can hurt you if you use it the wrong way.
    • All the tools featured in this guide are available in the Pro Tech Toolkit.
  2. Use a Phillips #00 screwdriver to remove the three screws. Pry and remove the panel with an opening pick. Pry and remove the panel with an opening pick.
    • Use a Phillips #00 screwdriver to remove the three screws.
    • Pry and remove the panel with an opening pick.
  3. Remove the speaker with a spudger.
    • Remove the speaker with a spudger.
    • Do not force it off. If you do, you could break your speaker.
  4. Remove the vibracall engine with the tweezers
    • Remove the vibracall engine with the tweezers
  5. Remove the mainboard with the spudger: Move on side here for detach the screen Pull up here for remove the mainboard
    • Remove the mainboard with the spudger:
    • Move on side here for detach the screen
    • Pull up here for remove the mainboard
    • The screen is soldered to the mainboard. If you are replacing your screen, you need a desoldering iron.
  6. Separate the rubber side of the keyboard from the rest of structure
    • Separate the rubber side of the keyboard from the rest of structure
  7. It's all done!
    • It's all done!
Stefano De Rossi
435 Reputatie
2 handleidingen geschreven
2 Opmerkingen
I have a samsung GT-E1200I and the port for the charger has died on me. I’ve tried it on several chargers and
there is no signal. I plugged it in and it just went dead. The problem is, I need to get the numbers I had. Is there any way of doing this?
edward - Antwoord
The numbers are maybe stored in the SIM? Have you tried to move the SIM on another phone?
Stefano De Rossi -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 328
