Inleiding
I've found a vacuum in my utility room. Since I almost never use it, I thought it was a good idea to see how it works... So let's go!!
Wat je nodig hebt
The 4.8 Rowenta vacuum can be used for a variety of purposes.
It is charged through its pedestal. The power of the pedestal is:
Input: 230V - 50 Hz - 7W (AC)
Output: 7.5V - 300 mA (DC)
Remove the screw securing the handle with a screwdriver.
Open the handle to see the inside using the flat screwdriver.
I removed the handle top and I found it to be quite difficult. I needed to use a plastic pry tool to pull the handle cover a bit to the outside (left and right) because there are some plastic holders that grab the handle. These plastic holder are placed two on each side and one at the end of the handle top. Force was required for the removal.
After this the body can be separated by pulling and pressing on the middle to detach the white plastic holders.
Één opmerking
This could use some discussion of how to replace the rechargeable batteries used in portable vacuum cleaners.
