Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Nintendo Wii Remote te repareren, gebruik onze reparatiehandleidingen.
  1. Rock Candy Remote Teardown, Getting your control: stap 1, afbeelding 1 van 3 Rock Candy Remote Teardown, Getting your control: stap 1, afbeelding 2 van 3 Rock Candy Remote Teardown, Getting your control: stap 1, afbeelding 3 van 3
    • To start dissembling this wii remote, turn it over and take the back off.
  2. Rock Candy Remote Teardown, Unscrewing the screws: stap 2, afbeelding 1 van 3 Rock Candy Remote Teardown, Unscrewing the screws: stap 2, afbeelding 2 van 3 Rock Candy Remote Teardown, Unscrewing the screws: stap 2, afbeelding 3 van 3
    • Then take the screws out and pry off the back, you should have four screws, 2 from the top and 2 from the bottom.
  3. Rock Candy Remote Teardown, Opening the control: stap 3, afbeelding 1 van 3 Rock Candy Remote Teardown, Opening the control: stap 3, afbeelding 2 van 3 Rock Candy Remote Teardown, Opening the control: stap 3, afbeelding 3 van 3
    • You need to pry off the back (do this carefully) , open it in half it should look like this (second picture). Take the motherboard off slowly and carefully, you should have 3 parts (third picture)
  4. Rock Candy Remote Teardown, Taking out the buttons: stap 4, afbeelding 1 van 3 Rock Candy Remote Teardown, Taking out the buttons: stap 4, afbeelding 2 van 3 Rock Candy Remote Teardown, Taking out the buttons: stap 4, afbeelding 3 van 3
    • From this part of the control take these pieces off carefully. You should have these pieces (second picture). After you should have something that looks like this (third picture). You have successfully disassembled your wii remote.
    • This will show you how to reassembling the wii remote if you are having trouble.
Giovanni Terrones
181 Reputatie
1 Handleiding geschreven
2 opmerkingen
This guide is great but it’s for a knock off brand called Rock Candy which is different to the official Nintendo controllers :)
Winter Lacekels - Antwoord
it is not a knockoff it's from a 3rd party
Justin Case - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 74
Altijd: 3,248
