Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Gereedschappen die in deze demontage worden gebruikt
Inleiding
This is a Teardown of one of iFixit's less known tools, the reversed nylon tweezers.
Deze demontage is geen reparatiehandleiding. Om je Tweezers te repareren, gebruik onze reparatiehandleidingen.
  1. This my friends, is the first ever iFixit-made-tool teardown on iFixit Stainless steel body and nylon tips, with the iFixit logo printed on it... Reversed so you can hold tiny Lego hats even when your hands are busy...
    • This my friends, is the first ever iFixit-made-tool teardown on iFixit
    • Stainless steel body and nylon tips, with the iFixit logo printed on it...
    • Reversed so you can hold tiny Lego hats even when your hands are busy...
  2. Time to tear it down! Its not often that regular Philips screws are used on modern devices! So far we've been able to take off a lot of the tool's construction using Only a PH0 screwdriver!
    • Time to tear it down!
    • Its not often that regular Philips screws are used on modern devices!
    • So far we've been able to take off a lot of the tool's construction using Only a PH0 screwdriver!
    • Have dreams come true?
    • We Remove the Last parts anddddd...
Aiden Baker
14.574 Reputatie
20 handleidingen geschreven
Where can you find the replacement parts?
Ethan Chow - Antwoord
Repairability: 11 out of 10.
Jake Rose - Antwoord
lol i actually needed this to fix mine
Luke - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 1,994
