Inleiding
Going to take apart my Power Mac 8600/250!
Tools:
#1 Phillips screwdriver
Spudger/Flathead screwdriver
Your hands!
Deze demontage is geen reparatiehandleiding. Om je Power Macintosh 8600(250) te repareren, gebruik onze reparatiehandleidingen.
The processor, firmly grasp and pull out.
Remove the 4 #1 Phillips screws
And push the 4 tabs off of the board
Any video card or usb card, mine happens to be an ethernet 10/100 card.
Unfortunately there are 6 spaces but only 3 slots on the motherboard :(
Remove the #1 Phillips screw and pull the card out.
Moving on to the CD, ZIP, and Floppy drives (best to close computer now)
Remove the bezels and if I had the top one remove that too.
Remove the 6 phillips screws and pull the metal frames out.
Remove the data and power cables
Pay special attention to this one, it has a clip on it, it helps to use a flathead or a spudger.
Pull the drives out of the bay.
Deze handleiding insluiten
Kies een formaat en kopieer de onderstaande code om deze handleiding in te sluiten als een kleine widget op uw site / forum.
Voorbeeld
