Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Table Lamp te repareren, gebruik onze reparatiehandleidingen.
  1. Portable Luminaries Lamp Teardown, Portable Luminaries Lamp Teardown: stap 1, afbeelding 1 van 1
    • The attached picture displays the lamp before the teardown.
  2. Portable Luminaries Lamp Teardown: stap 2, afbeelding 1 van 1
    • Remove the power cord from the wall socket outlet
    • Make sure to follow this step. There may be a danger of severe electric shock if you proceed to tear down the device without removing the plug
  3. Portable Luminaries Lamp Teardown: stap 3, afbeelding 1 van 2 Portable Luminaries Lamp Teardown: stap 3, afbeelding 2 van 2
    • Place the lamp gently on its side on a flat surface
    • Twist the lightbulb counter-clockwise to remove it from the lamp's head.
    • After lightbulb removal, the component attaching the lightbulb and lamp's head is exposed.
  4. Portable Luminaries Lamp Teardown: stap 4, afbeelding 1 van 2 Portable Luminaries Lamp Teardown: stap 4, afbeelding 2 van 2
    • Next, the light bulb housing can be detached from the lamp head
    • Using the Philips screw driver, unscrew the two 5mm diameter screws within the light bulb housing
  5. Portable Luminaries Lamp Teardown: stap 5, afbeelding 1 van 2 Portable Luminaries Lamp Teardown: stap 5, afbeelding 2 van 2
    • Keep the lamp on its side
    • The bottom is now exposed and two screws are visible
    • Using the Philips Screwdriver, unscrew the two 7mm gold screws from the bottom of the base
  6. Portable Luminaries Lamp Teardown: stap 6, afbeelding 1 van 2 Portable Luminaries Lamp Teardown: stap 6, afbeelding 2 van 2
    • Once the screws attached to the base are removed, the base's bottom lid detaches from the lamp.
    • Within the base resides two components: the lamp's weight and the switch.
    • The weight sits on the bottom base lid, so it separates without the use of additional tools.
  7. Portable Luminaries Lamp Teardown: stap 7, afbeelding 1 van 1
    • The white container holding the switch does not need tools for opening.
    • The switch container is clipped shut and opens by unlatching the tab
Brenden
56 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,667
