Ga door naar hoofdinhoud
Wat je nodig hebt
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je PlayStation 2 te repareren, gebruik onze reparatiehandleidingen.
  1. PlayStation 2 Teardown, PlayStation 2 Teardown: stap 1, afbeelding 1 van 3 PlayStation 2 Teardown, PlayStation 2 Teardown: stap 1, afbeelding 2 van 3 PlayStation 2 Teardown, PlayStation 2 Teardown: stap 1, afbeelding 3 van 3
    • Here we have the system console fully assembled.
    • The USB Ports.
    • The S400 ports
    • The Optical Drive
    • The reset button
    • The eject button
  2. PlayStation 2 Teardown: stap 2, afbeelding 1 van 2 PlayStation 2 Teardown: stap 2, afbeelding 2 van 2
    • These are the only tools that we will need. 4 screwdrivers and a tweezer.
    • In the next photo we can see the console, the joystick, the wires and a memory card.
    I don't have. A flat head sturdriver
    myjiki - Antwoord
  3. PlayStation 2 Teardown: stap 3, afbeelding 1 van 2 PlayStation 2 Teardown: stap 3, afbeelding 2 van 2
    • In the Back, in this case we have a Ethernet adapter, to play online and to use with a Hdd.
    • And the cooler,
    • The power switch
    • The AC in.
    • The Av out
    • And the digital output (optical)
    Where can I buy an av out port replacement
    DarkruneyGaming - Antwoord
  4. PlayStation 2 Teardown: stap 4, afbeelding 1 van 3 PlayStation 2 Teardown: stap 4, afbeelding 2 van 3 PlayStation 2 Teardown: stap 4, afbeelding 3 van 3
    • Lets start the teardown. At first we use a Flathead screwdriver to remove the ethernet adapter.
    • Remove these 2 screws with a Flathead screwdriver.
    • And is quite simple to pull.
    I have the ethernet adaptor with mine but no hard drive, how do you get the hard drive to work in it?
    Chris Green - Antwoord
    Citaat van Chris Green:
    it is a mod. you can look it up
    DustySeven - Antwoord
  5. PlayStation 2 Teardown: stap 5, afbeelding 1 van 1
    • This is the expansion bay, where the hard drive goes.
    I got my ps2 from flea market and it didn't have a lid to cover up the expansion bay is that ok to leave it like that
    Plushbeatzz gaming - Antwoord
  6. PlayStation 2 Teardown: stap 6, afbeelding 1 van 2 PlayStation 2 Teardown: stap 6, afbeelding 2 van 2
    • Turn the console upside down.
    • Using a small Flathead screwdriver, remove the screw protections. In this model, we have 8 of them.
  7. PlayStation 2 Teardown: stap 7, afbeelding 1 van 3 PlayStation 2 Teardown: stap 7, afbeelding 2 van 3 PlayStation 2 Teardown: stap 7, afbeelding 3 van 3
    • Under the protection, suprise! a screw!
    • Remove all eight (8) screws with your Philips "0" screwdriver.
    • Yes, hard work!
    Hello, nice review! Can you help me out with a question i have? I have this PS2 Fat, i miss those big long screws that hold the outside shell, i need to buy them (if i can) so i can only find long screws from the PS3 4000, does those screws fit into PS2 Fat aswell? Do you know?thanks!
    Cheerious - Antwoord
  8. PlayStation 2 Teardown: stap 8, afbeelding 1 van 2 PlayStation 2 Teardown: stap 8, afbeelding 2 van 2
    • Put the console in the normal horizontal position, and pull the top cover from back to front.
    You will need to pull back the anti-tamper seal along the rear left corner.
    Wade - Antwoord
  9. PlayStation 2 Teardown: stap 9, afbeelding 1 van 3 PlayStation 2 Teardown: stap 9, afbeelding 2 van 3 PlayStation 2 Teardown: stap 9, afbeelding 3 van 3
    • This model has a flat cable to the reset and eject button. Take extreme caution to not destroy it.
    • Remove the button structure just pulling with a small Flathead screwdriver.
  10. PlayStation 2 Teardown: stap 10, afbeelding 1 van 1
    • The button structure comes out of the case. It have some tape to prevent a new destruction. Yes, I already destroyed this flat cable.
  11. PlayStation 2 Teardown: stap 11, afbeelding 1 van 3 PlayStation 2 Teardown: stap 11, afbeelding 2 van 3 PlayStation 2 Teardown: stap 11, afbeelding 3 van 3
    • Remove the two screws with a Philips "0" screwdriver to deatach the controller port.
    I've tried cleaning my memory slot ports. They look fine. I'm wondering if I just have crap luck and got 2 bad cards or do I need to replace the part.
    My controller ports work fine though. Same cable I'd imagine
    AbsoluteQuinoa - Antwoord
  12. PlayStation 2 Teardown: stap 12, afbeelding 1 van 2 PlayStation 2 Teardown: stap 12, afbeelding 2 van 2
    • Here we remove the screws from the cooler and the main power switch
    After reassembly, I have a fifth screw identical to the ones shown in Step 11 and Step 12 left over, any idea where it goes?
    Thaddeus Warner - Antwoord
    When you remove the power/ac plug there is a spot for the screw underneath.
    Jeff Friesen -
  13. PlayStation 2 Teardown: stap 13, afbeelding 1 van 2 PlayStation 2 Teardown: stap 13, afbeelding 2 van 2
    • Pull the fan up carefully so you don't break the wire.
    • Pull up the fan mount.
    I found that there was a little bit of tape holding the fan cable to the fan which prevented me from removing it until I removed the fan connector after step 18.
    Shannon Hamilton - Antwoord
  14. PlayStation 2 Teardown: stap 14, afbeelding 1 van 2 PlayStation 2 Teardown: stap 14, afbeelding 2 van 2
    • The power cable goes further inside the case. It's better to remove it in a future step.
    • The fan wire also goes more inside the case. Take extreme care not to destroy it because it is very small.
  15. PlayStation 2 Teardown: stap 15, afbeelding 1 van 3 PlayStation 2 Teardown: stap 15, afbeelding 2 van 3 PlayStation 2 Teardown: stap 15, afbeelding 3 van 3
    • Lets turn the console upside down again, with caution because the pieces are locked, and just in the next step we can remove them.
  16. PlayStation 2 Teardown: stap 16, afbeelding 1 van 2 PlayStation 2 Teardown: stap 16, afbeelding 2 van 2
    • Lets remove the bottom case.
  17. PlayStation 2 Teardown: stap 17, afbeelding 1 van 3 PlayStation 2 Teardown: stap 17, afbeelding 2 van 3 PlayStation 2 Teardown: stap 17, afbeelding 3 van 3
    • This is the power source board. remove the 4 screws where I marked in blue.
  18. PlayStation 2 Teardown: stap 18, afbeelding 1 van 3 PlayStation 2 Teardown: stap 18, afbeelding 2 van 3 PlayStation 2 Teardown: stap 18, afbeelding 3 van 3
    • Looking from the back, pull up the board, releasing from the pins of the main board.
    • Finally you can remove the power switch.
    • And this is the power source board.
    • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  19. PlayStation 2 Teardown: stap 19, afbeelding 1 van 3 PlayStation 2 Teardown: stap 19, afbeelding 2 van 3 PlayStation 2 Teardown: stap 19, afbeelding 3 van 3
    • Now we remove the expansion bay grid.
    • And now is the time to remove the fan wire from the main board, using a precision tweezer. But.. I can't, it is simply stuck. I already removed this ealier, but now is harder, so I will try later, in the end of the teardown.
    I just broke the fan pins because you have to push the connector to the side and then up. There are 2 hooks that hold the connector in place.
    Sean Brownell - Antwoord
  20. PlayStation 2 Teardown: stap 20, afbeelding 1 van 3 PlayStation 2 Teardown: stap 20, afbeelding 2 van 3 PlayStation 2 Teardown: stap 20, afbeelding 3 van 3
    • Remove the isolation cover from the metal case.
    • Remove the small screws using a thin crosshead screwdriver.
    • And release the metal case from the DVD player, as indicated, using a small flat screwdriver
    There are 4 more screws that you do not have marked that I needed to remove before this metal case could be removed in the next step. Three of them on this side same as the ones circled in orange. One of the is on the other side near the audio out connector.
    Jssamp - Antwoord
    In the models that I took apart, there was only 3, two near the back of the DVD drive and one near the middle. The PS2 in this teardown has clearly been taken apart before and it looks like they forgot to put some screws back in and even broke the metal case where one screw should go.
    Shannon Hamilton -
  21. PlayStation 2 Teardown: stap 21, afbeelding 1 van 3 PlayStation 2 Teardown: stap 21, afbeelding 2 van 3 PlayStation 2 Teardown: stap 21, afbeelding 3 van 3
    • Now you can remove the metal case and find the main board.
    • Look, the flat cables! Now is the time to remove them. Be gentle please.
  22. PlayStation 2 Teardown: stap 22, afbeelding 1 van 3 PlayStation 2 Teardown: stap 22, afbeelding 2 van 3 PlayStation 2 Teardown: stap 22, afbeelding 3 van 3
    • There are 2 more and the DVD player is free.
  23. PlayStation 2 Teardown: stap 23, afbeelding 1 van 2 PlayStation 2 Teardown: stap 23, afbeelding 2 van 2
    • Now you can turn upside down again, and remove the metal protection.
    • This is the other side of the main board.
  24. PlayStation 2 Teardown: stap 24, afbeelding 1 van 3 PlayStation 2 Teardown: stap 24, afbeelding 2 van 3 PlayStation 2 Teardown: stap 24, afbeelding 3 van 3
    • Well, the try to remove the cooler wire was a total failure.
    • The plug is made to deatach, but it is old. The plug had turned into one piece, and broke the soldering.
    • Well, I'll find a way to fix it. I always do =)
    I did the same thing on my slim but to my systems battery. Will this prevent the system from working?
    NJBmusic - Antwoord
    How did you fix same happened to me
    Francisco Torres - Antwoord
  25. PlayStation 2 Teardown: stap 25, afbeelding 1 van 1
    • This is the end of the teardown.
    • From top, from the left: Ethernet adapter, Ps2 case, Hdd, Cooler, Cooler grid, bottom metal cover protection, screws protectors, screws, Controller board, Power swtich, Power source board, Plastic cover to isolate the power source board, top metal cover, DVD Drive, Expansion Bay cover, main board, reset/eject structure.
    You probably shouldn’t put electronics on cloth, but I guess its about 9 years too late for that.
    Johnny Danger - Antwoord
Pollux
650 Reputatie
1 Handleiding geschreven
13 opmerkingen
reverse procedures..step by step..
a to z cellutions belize - Antwoord
Yep in reverse, take your time or you'll be like me breaking things and having to rig it haha. Put the shielding back together, drive, power board, the other shield for hard drive. Everything, plug all connections. Even power-reset buttons. Then put it on the bottom casing, connect controller ports and close it up with top casing.
juan hernandez - Antwoord
How did you fix the flat cable?
Bigs - Antwoord
If a cable is ripped or broken, unfortunately there is no way to fix it. You will have to replace the cable.
Molten Toast -
I put a lot of layers of tape on mine, the last owner of my system was very naughty and disassembled the system when it was still under warranty, so the cable was brokem
John Doe -
do you have the list of screws required for this? i am missing a few trying to locate the size specs
Corey Smith - Antwoord
All i see is the 20 legged modchip-kraken lurking in one of those pics ;)
mgwara - Antwoord
Hi, I have a problem with a hardly used PS2. When I turn it on it only displays some coloured squares. I don’t know if the video chip has gone. Do you have any ideas??
agfa gaevart - Antwoord
i'd need to see it to tell you whats wrong. what do you mean by coloured squares??
Camdyn -
So I’m curious does all PS2s take thermal paste? Bcuz I noticed the cpu/gpu chip looked like it had some on it b4!
VAMPRESS23 - Antwoord
I've only disassembled some of the older models, and they only had thermal pads. Possibly the slim models used paste.
Shannon Hamilton -
And I was going to get inside as I need to change the coin battery but I'm not going to bother it's ridiculous just to get to it
Nakatomi Uk - Antwoord
This helped me teardown an old PS2 I just bought a few days ago.
With your help, I was able to give it a thorough clean inside and out and swap the BIOS battery. It looks and works almost like brand new now.
Thank you so much Pollux! 🙂❤️
SuperDadAndBreadMan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 44
Afgelopen 7 dagen: 376
Afgelopen 30 dagen: 2,008
Altijd: 155,634
