Wat je nodig hebt
The Pebble Time Round was last manufactured in 2015, and yet has a loyal following and afterlife.
Follow along to dissect your favorite e-paper smartwatch.
Use a guitar pick and push on the left or right side, above the buttons to separate the case from the glass front.
There are three small springsthat are embedded in the casing, just waiting to pop out. Once you separate the case enough to see inside, look and make sure they don’t come loose.
The glass face should come off with a little coaxing from a pick.
Gently separate the white touch panel from the e-paper screen. These fall apart easily but are held together by two cables.
Use a spudger to detach the small cable from the white touch panel. This cable is for the microphone and vibration motor.
Use a spudger to detach the second cable. This cable is for the display. The second picture shows it already detached.
Insert a pick between the e-paper screen and the bezel ring. Slide the pick all the way around the screen, separating the two pieces.
There is a small amount of tape holding together the two cables that are attached to the epaper screen and the white backlight panel. Pull this off with tweezers.
Gently pull apart the cables. They are only glued together and can be pulled apart easily.
The glass face
The bezel ring
The e-paper screen
The backlight panel
Use a spudger to disconnect the battery cable from the motherboard.
Use a small phillips screwdriver (PH000) to remove the screws.
The motherboard can now be lifted out of the case.
Use tweezers to pull the metal bracket that holds the microphone and vibration motor cable to the rear case. It should slide up and out of the case.
The vibration motor is glued to the case, use a spudger to pry it out
The rest of the cable assembly is glued to the case, but not as strongly. Once the vibration motor glue has been separated from the case, the rest of the cable assembly can be gently pulled out, too.
All that is left is the battery, and it is also glued to the case.
Slide a thin tool under the contacts at the top of the battery. Now carefully slide a plastic pick under the battery and separate it from the case.
The front glass, made of 2.5d gorilla glass.
The bezel ring. It comes in two colors (white and black) and three styles (numbers, plain, plain with ribs)
The e-paper screen, which has the ability to show 64 colors.
The backlight panel
The vibration motor and mic cable assembly
The 58-mAh battery that somehow provides over 24 hours of use on a single 15 minute charge.
The motherboard, with a Spansion chip.
The full case. Congrats!
5 opmerkingen
Great teardown! It only took six years for a good detailed teardown to be published. Thanks for taking the time to post this for those who still use a pebble time round.
Question, does the battery have to be desoldered from the motherboard to be removed? There’s a battery replacement for purchase on ifixit that does not require soldering, so I am wondering if this battery replacement will be simple without having to desolder the old battery.
Thanks!
Ryan
I also would love to know. Soldering & batteries feels like a bad combination
No need, as you can see in Step 12. If you have a battery replacement with the contacts already soldered on (like the one here on iFixit), you can unplug the connectors and connect the new one.
I haven’t ever replaced a battery, but I’ve seen people mention that they’ve done it on the /r/pebble subreddit. I’ve also seen some youtube videos. The main thing I saw people complaining about in the subreddit was gluing the pebble back together was difficult.
What is called “touchpanel” here more likely is the display backlight, the Pebble Time Round does not have a touchscreen but a backlit screen.
The term “e-paper” for the display is misleading. E-paper is often used as a term for e-ink displays, which is a totally different technology than what the Pebble uses. The Pebble uses a fully reflective low power display much more similar to an LCD than to e-ink. I am not fully sure but I think the technology is based on Sharp’s Memory In Pixel LCDs. The first ones of these were based on some polymer instead of liquid crystals, but I am not completely sure here. But Sharp still makes this type of displays, also with color, the same 64 colors the Pebble has. The Pebble’s display was IIRC made by some “Japan Display” corp or similar - really a long time ago I researched that. Ah, right, here we go:
https://www.j-display.com/english/produc...
They used to list pretty much exactly the Pebble display back in 2015/2016 but obviously moved on.
