Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Panasonic EB TX320ASW te repareren, gebruik onze reparatiehandleidingen.
  1. Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: stap 1, afbeelding 1 van 2 Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: stap 1, afbeelding 2 van 2
    • To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
  2. Panasonic EB TX320ASW Teardown: stap 2, afbeelding 1 van 1
    • To remove battery push clip in; battery will pop out.
  3. Panasonic EB TX320ASW Teardown: stap 3, afbeelding 1 van 1
    • Using a Star 3.0 bit, remove 4 screws in battery compartment.
  4. Panasonic EB TX320ASW Teardown: stap 4, afbeelding 1 van 2 Panasonic EB TX320ASW Teardown: stap 4, afbeelding 2 van 2
    • To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
  5. Panasonic EB TX320ASW Teardown: stap 5, afbeelding 1 van 1
    • To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
    • If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
  6. Panasonic EB TX320ASW Teardown: stap 6, afbeelding 1 van 3 Panasonic EB TX320ASW Teardown: stap 6, afbeelding 2 van 3 Panasonic EB TX320ASW Teardown: stap 6, afbeelding 3 van 3
    • To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
  7. Panasonic EB TX320ASW Teardown: stap 7, afbeelding 1 van 1
    • To remove speaker cover, pull out silver plate.
  8. Panasonic EB TX320ASW Teardown: stap 8, afbeelding 1 van 2 Panasonic EB TX320ASW Teardown: stap 8, afbeelding 2 van 2
    • After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
    • If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
  9. Panasonic EB TX320ASW Teardown: stap 9, afbeelding 1 van 2 Panasonic EB TX320ASW Teardown: stap 9, afbeelding 2 van 2
    • To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
  10. Panasonic EB TX320ASW Teardown: stap 10, afbeelding 1 van 3 Panasonic EB TX320ASW Teardown: stap 10, afbeelding 2 van 3 Panasonic EB TX320ASW Teardown: stap 10, afbeelding 3 van 3
    • To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
  11. Panasonic EB TX320ASW Teardown: stap 11, afbeelding 1 van 2 Panasonic EB TX320ASW Teardown: stap 11, afbeelding 2 van 2
    • To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
    • If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
Andrew Foss
10 Reputatie
1 Handleiding geschreven
UW Stout, Team 5-2, Zhou Fall 2011 Lid van UW Stout, Team 5-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G2
2 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 3,468
