Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je PSP Go te repareren, gebruik onze reparatiehandleidingen.
  1. PSP Go Teardown, PSP Go Teardown: stap 1, afbeelding 1 van 2 PSP Go Teardown, PSP Go Teardown: stap 1, afbeelding 2 van 2
    • Oh joy! Oh joy! Guess what we got our hands on this time! Its the brand spanking new Sony PSP Go!
    • Although the design of the PSP Go is different from previous PSP models, the PSP Go is not intended to replace its much loved older brother, the PSP 3000.
    Also this is how you replace the Start and Select Buttons:
    https://imgur.com/gallery/JRRsJku
    Player - Antwoord
  2. PSP Go Teardown: stap 2, afbeelding 1 van 3 PSP Go Teardown: stap 2, afbeelding 2 van 3 PSP Go Teardown: stap 2, afbeelding 3 van 3
    • Such an elegant backside... But where is the UMD drive? Let's have a moment of silence. R.I.P. UMD drive, we hardly knew ye.
    • The PSP Go measures at 128 x 16.5 x 69 mm and weighs in at 5.6 oz (including the internal battery).
    • Unlike previous PSP models, the PSP Go makes do with 16 GB of internal flash memory.
    • Oooooh it slides up to reveal the gamepad!
    • The product label has the usual power requirements and FCC warnings. It appears even Japanese companies have their products manufactured in China.
    there're rumors saying PSP GO is manufactured by Foxconn,
    no wonder it's made in China.
    also, most previously models of PSP are made in China, too.
    GeekFox - Antwoord
    Can't u open the battery and go through the components? :)
    jim mij - Antwoord
  3. PSP Go Teardown: stap 3, afbeelding 1 van 2 PSP Go Teardown: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Phillips #0 Screwdriver
    $5.49
    Koop
    • Removing the necessary screws required to gain access into the innards of the PSP Go.
    • On this device, all screws are readily accessible and use a common Phillips #0 head. No hidden tabs or tri-wing screws here.
    • With a non-soldered battery and Phillips head screws, why doesn't Sony approve of DIY battery replacement?
    • We can think of only one reason: it starts with "cha," and ends with "ching." That's right, the sound of the cash register.
  4. PSP Go Teardown: stap 4, afbeelding 1 van 3 PSP Go Teardown: stap 4, afbeelding 2 van 3 PSP Go Teardown: stap 4, afbeelding 3 van 3
    • A simple flick of a PSP opening tool and presto!
    • Ladies and Gentlemen, behold! The inside of the PSP Go.
    • Unlike the Zune HD or the iPod Classic, the Go uses no metal internal framework. In fact, it has no internal framework; all structural integrity is provided by the plastic outer cases.
  5. PSP Go Teardown: stap 5, afbeelding 1 van 2 PSP Go Teardown: stap 5, afbeelding 2 van 2
    • We begin our dissection by disconnecting a few connectors and removing a couple screws.
    • It was clear the board wouldn't come out without first removing the triggers. So we decided to start with the left trigger button.
    • The trigger button ribbon cables are connected to the board with ZIF connectors; a careful flick with the PSP opening tool released the clamp and freed the ribbon cable.
  6. PSP Go Teardown: stap 6, afbeelding 1 van 2 PSP Go Teardown: stap 6, afbeelding 2 van 2
    • Firmly stuck to the battery is a trilingual Warranty Void seal. They really covered all bases with this one, as long as you know English, French, or Spanish.
    • Good news: the battery is not soldered to the board.
    • Bad news: unfortunately, you have to peel the warranty sticker back to remove the battery.
    • But more good news: if you're careful, you can remove the battery without disturbing the "VOID" portion of the seal, but we didn't tell you that.
    • Just slide a PSP opening tool in between the battery and sticker. Work your way gently side-to-side, until the battery is free from the sticker. Presto-changeo!
  7. PSP Go Teardown: stap 7, afbeelding 1 van 1
    • The battery's a Li-ion 3.7V, 930 mAh, 3.5Wh unit.
    • Here's how the three major handheld gaming devices stack up in the battery department:
    • PSP Go: 930 mAh, unofficially user replaceable
    • DSi: 840 mAh, officially user replaceable
    • iPod touch 3rd Gen: 789 mAh, unofficially user replacable, requires difficult soldering
    • The PSP wins on capacity, and the DSi wins on serviceability. The touch, well, if you can't say something nice...
  8. PSP Go Teardown: stap 8, afbeelding 1 van 2 PSP Go Teardown: stap 8, afbeelding 2 van 2
    • Pull the cosmetic cover away from the bottom edge of the Go, near the audio jack.
    • Two additional screws secure the joystick to the Go.
    • Steel covers were placed over the majority of the chips to guard them from electromagnetic interference.
  9. PSP Go Teardown: stap 9, afbeelding 1 van 3 PSP Go Teardown: stap 9, afbeelding 2 van 3 PSP Go Teardown: stap 9, afbeelding 3 van 3
    • After disconnecting the Select/Start button, volume buttons, and the headphone jack, the logic board simply lifts out of the case.
    • The analog joystick comes right out with the logic board.
    Minor typo on the second part of the sentence in step 9:
    "the logic board simply lifts out of the The analog joystick comes right out with the logic board." :D
    Since both the iPod Touch and the PSP Go don't have internal chassis, how would you compare the rigidity/sturdiness between the two products? Yes I know, strange question.....
    DUSTmurph - Antwoord
    Citaat van DUSTmurph:
    The iPod Touch is much more rigid than the Go because the rear case of an iPod touch is made of stainless steel, and the front glass panel increases its rigidity. It is very slim and compact so most of the internal components add to its rigidity. The case of the PSP go is almost entirely plastic, so when it is in the open position you can flex it pretty easily. When it is closed the rigidity obviously increases, but you can't play games with the device closed ;).
    Andrew Bookholt - Antwoord
    I changed the analog with 2 different new analogs but its still drifting. I play hours with no problem then all of a sudden in a different game which I start its drifting, surprisingly its usually happening on the same games.
    I dont understand whether its a software or hardware problem.
    Ali Aslan - Antwoord
    any idea how to take out the start select ribbon cable out? my one is faulty and replacing to a new one. But could not think how to take it off…
    Farhan Dahari - Antwoord
    figured it out. carve the start slect button from the front.. turns out its glued to the front chasis. took out the start select button from there…
    Farhan Dahari -
  10. PSP Go Teardown: stap 10, afbeelding 1 van 2 PSP Go Teardown: stap 10, afbeelding 2 van 2
    • With the board out, we can continue tearing into the Go.
    • A couple screws must be removed to separate the display assembly from the lower case.
    • With the lower case and logic board gone, you can see the details of the metal slider mechanism. That display ribbon cable must be designed for wear from millions of opening/closing cycles.
    So how do we replace the flex ribbon for the start and select?
    Anddy Ayala - Antwoord
  11. PSP Go Teardown: stap 11, afbeelding 1 van 3 PSP Go Teardown: stap 11, afbeelding 2 van 3 PSP Go Teardown: stap 11, afbeelding 3 van 3
    • We used a PSP opening tool to lift the LCD display panel out of the sliding upper case.
    • Two small speakers (with the mint green labels) stream sound from the front of the Go. They are printed with the serial number:
    • EAS1D129A VNXG9618V17a
  12. PSP Go Teardown: stap 12, afbeelding 1 van 2 PSP Go Teardown: stap 12, afbeelding 2 van 2
    • The backside and the frontside of the PSP Go logic board, with joystick still attached.
    • Now we will turn our attention to identifying the many chips that make the Go... well... go.
    • The sheer number of chips and EMI covers is amazing. The device certainly has a large number of dedicated-function chips, as opposed to having a few large multi-tasking chips.
  13. PSP Go Teardown: stap 13, afbeelding 1 van 2 PSP Go Teardown: stap 13, afbeelding 2 van 2
    • The first picture includes:
    • Sony Computer Entertainment CXD2986A1GG
    • 9110563 20AK2L 0846
    • In the second picture:
    • SAMSUNG 922 KLSAG8DAAD-B202 flash memory provides 16GB of internal storage.
    • CIRRUS 42L52CNZ CF1S0917 low power, stereo codec with headphone and speaker amps.
    why, it looks like something was cut off?
    GeekFox - Antwoord
    any idea where the PSP Go teardown has gone?
    bcsyn -
    It will be back very soon.
    Kyle Wiens -
    Can you take the cover off the Alps module. Thanks
    BCBC - Antwoord
  14. PSP Go Teardown: stap 14, afbeelding 1 van 3 PSP Go Teardown: stap 14, afbeelding 2 van 3 PSP Go Teardown: stap 14, afbeelding 3 van 3
    • SHARP 0923 7y LR388G1 TFT-LCD controller for video out.
    • OKI L86V7657 9175902J
    • The second picture is of the QZ7-001A 95D ALPS 002433 A73457 Bluetooth communication chip.
    • For the third picture:
    • SCEI 923KMO3 4053
    • U3031 9M93
    • The small object highlighted in green on the third picture is the surface mounted microphone.
  15. PSP Go Teardown: stap 15, afbeelding 1 van 2 PSP Go Teardown: stap 15, afbeelding 2 van 2
    • Highlighted in red on the first picture is the Fujitsu power processing module with serial number:
    • Fujitsu LTD MB44C018A 0925 M64 E1
    • Shown in the second picture, the FOXCONN T60H975 wireless chip provides 802.11b WLAN support.
    • Still no G or N support...
    You're kidding me; they haven't added in even N support yet? I know that most routers these days are at least G/B compatible but even so...talk about cheapskates.
    MD5Hash - Antwoord
  16. PSP Go Teardown: stap 16, afbeelding 1 van 1
    • And there you have it: the Go in pieces.
    • Curious how the PSP stacks up the the handheld gaming competition on the inside? We have both a DSi teardown and an iPod touch teardown.
    • Be sure to keep an eye on our teardown page for an inside look at the latest gadgets!
    haha, your warranty is still good!
    Arkanoid0 - Antwoord
    Cool teardown. I'm a late adopter. It's nice to see what I'm buying. Thanks ifixit! The battery guide will come in handy.
    Redsyrup - Antwoord
    Is there an ability to connect a umd drive I am hoping to make a home console from a PSP go as I can use a ps3 control on it, I have found a circuit board to convert the m2 to SD/micro SD
    Aaron Smith - Antwoord
5 opmerkingen
Is there a way to remove the start & select buttons on the GO? If so can some add pictures on how to do this. Thanks in advance.
Pat - Antwoord
I'd say you can follow this guide and just push the buttons out of the front case.
Andrew Bookholt -
Is there anyway to connect a umd drive from any of the other PSP preferred 1000 as I am planing to making a PSP console hopefully from a PSP go as this has the Bluetooth in it to connect a ps3 controller I know you may think it's pointless but it's something I like to do
What are the psp go's tft screen pinouts?
Jonathan Nunez - Antwoord
what is the Name of IC on Step13 first picture number starting with 44C01 and also what is the name of circuit, in my psp go that IC Heating when putting a battery also not turn on its dead, please help to find a fault to my console
MUTHU M - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 368
Altijd: 140,239
