Wat je nodig hebt
Then, insert a spudger between the L button and the face plate and separate them. Then, do the same on the right.
Then slide the face plate down towards the bottom of the screen to release the bottom clips.
Ensure you support the face plate as the front buttons are still connected with a fragile ribbon cable.
2 opmerkingen
My aim was to clean the inside, so I only disassembled it up to the screen, but I accidentally pulled the socket where the volume button is connected hard.So that black thing broke but the part that goes into the socket is intact. Finally, after cleaning it, I plugged it into the socket, then I put the LCD screen into its socket and placed it. Finally, after putting the device back into its parts, I pressed the power button but the screen did not come on.
What black thing are you referring to?
When you turned it on did the top LEDs come on or did they stay off?
