Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je PSP 300x te repareren, gebruik onze reparatiehandleidingen.
  1. PSP 300x Teardown, PSP 300x Teardown: stap 1, afbeelding 1 van 2 PSP 300x Teardown, PSP 300x Teardown: stap 1, afbeelding 2 van 2
    • The first picture is a view of the front of the PSP-3000. The second picture is of the back.
  2. PSP 300x Teardown: stap 2, afbeelding 1 van 2 PSP 300x Teardown: stap 2, afbeelding 2 van 2
    • Lift the covering from the left side on the back of the PSP to reveal the battery.
    • Pull up on the top at the top of the battery with your fingernail and remove it.
  3. PSP 300x Teardown: stap 3, afbeelding 1 van 3 PSP 300x Teardown: stap 3, afbeelding 2 van 3 PSP 300x Teardown: stap 3, afbeelding 3 van 3
    • Using a spudger or fingernail (spudger set available at iFixit) http://www.ifixit.com/Tools/Metal-Spudge... peel back the warranty sticker that was behind the battery.
    • Using a Phillips #0 screwdriver (screwdriver available at iFixit Tools), Unscrew all four screws from the back of the PSP.
    • Two from behind the battery.
    • And two on the right side of the PSP.
  4. PSP 300x Teardown: stap 4, afbeelding 1 van 2 PSP 300x Teardown: stap 4, afbeelding 2 van 2
    • Unscrew two screws from the top of the PSP.
    • Turn the PSP around, and unscrew a single screw from the bottom edge.
  5. PSP 300x Teardown: stap 5, afbeelding 1 van 2 PSP 300x Teardown: stap 5, afbeelding 2 van 2
    • Starting from the 'R' trigger, slide the spudger in between the outer casing the the PSP, and gently pry off the casing.
    • Remove the outer casing completely.
  6. PSP 300x Teardown: stap 6, afbeelding 1 van 3 PSP 300x Teardown: stap 6, afbeelding 2 van 3 PSP 300x Teardown: stap 6, afbeelding 3 van 3
    • Push the homebar to the right to release the tab on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    • Slowly begin to lift the LCD screen off the PSP from the top edge.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
  7. PSP 300x Teardown: stap 7, afbeelding 1 van 3 PSP 300x Teardown: stap 7, afbeelding 2 van 3 PSP 300x Teardown: stap 7, afbeelding 3 van 3
    • Using a spudger or fingernail, flip the small brown locks on the four ribbon cable connectors up.
    • WARNING! Be carefull removing the small ribbion from the LCD connector, it is very delicate. Using a spudger lift the black plastic up, NOT the white part on the connector!
    • Pull all four ribbon cables out, and remove the LCD screen and homebar from the PSP.
  8. PSP 300x Teardown: stap 8, afbeelding 1 van 3 PSP 300x Teardown: stap 8, afbeelding 2 van 3 PSP 300x Teardown: stap 8, afbeelding 3 van 3
    • Remove the small metal bar from the top edge of the PSP. (This was helping to hold the LCD screen in place)
    • Remove the button pad from the PSP.
  9. PSP 300x Teardown: stap 9, afbeelding 1 van 3 PSP 300x Teardown: stap 9, afbeelding 2 van 3 PSP 300x Teardown: stap 9, afbeelding 3 van 3
    • Unscrew the the screw securing 'L' trigger.
    • Remove the white plastic piece that holds the 'L' trigger in place.
    • Remove the 'L' trigger from the PSP.
  10. PSP 300x Teardown: stap 10, afbeelding 1 van 3 PSP 300x Teardown: stap 10, afbeelding 2 van 3 PSP 300x Teardown: stap 10, afbeelding 3 van 3
    • Unscrew the 'R' trigger and remove both pieces. (Refer to step nine by applying the procedures to this, the right, side)
  11. PSP 300x Teardown: stap 11, afbeelding 1 van 2 PSP 300x Teardown: stap 11, afbeelding 2 van 2
    • Remove the screw from the bottom left edge.
    • Being careful not to break the ribbon cable, use the spudger, to carefully peel the adhesive button from below the 'L' trigger.
  12. PSP 300x Teardown: stap 12, afbeelding 1 van 3 PSP 300x Teardown: stap 12, afbeelding 2 van 3 PSP 300x Teardown: stap 12, afbeelding 3 van 3
    • Using the spudger or fingernail, flip up the brown lock on the ribbon cable.
    • Remove the cable from the connector and remove the entire black piece from the PSP.
    • Remove the screw from the analog stick.
  13. PSP 300x Teardown: stap 13, afbeelding 1 van 3 PSP 300x Teardown: stap 13, afbeelding 2 van 3 PSP 300x Teardown: stap 13, afbeelding 3 van 3
    • Unlock and remove the ribbon cable connection the analog stick to the main board.
    • Remove the analog stick from the PSP.
  14. PSP 300x Teardown: stap 14, afbeelding 1 van 3 PSP 300x Teardown: stap 14, afbeelding 2 van 3 PSP 300x Teardown: stap 14, afbeelding 3 van 3
    • Unlock and remove the ribbon cable from the power switch on the right side of the PSP.
    • Unscrew and remove the screw from the yellow power jack.
    • Carefully bend back the black tab holding the power jack in place and start pulling the plug up to release it from this clip.
  15. PSP 300x Teardown: stap 15, afbeelding 1 van 1
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
  16. PSP 300x Teardown: stap 16, afbeelding 1 van 2 PSP 300x Teardown: stap 16, afbeelding 2 van 2
    • Push the black tab at the bottom of the speaker over.
    • The speaker should pop out of place, and you should be able to remove it easily.
  17. PSP 300x Teardown: stap 17, afbeelding 1 van 3 PSP 300x Teardown: stap 17, afbeelding 2 van 3 PSP 300x Teardown: stap 17, afbeelding 3 van 3
    • Pull the wireless antenna cable from its plug.
    • Unlock and remove both ribbon cables from the mother board.
  18. PSP 300x Teardown: stap 18, afbeelding 1 van 2 PSP 300x Teardown: stap 18, afbeelding 2 van 2
    • Remove the screw from the power switch board.
    • Remove the power switch assembly/board.
  19. PSP 300x Teardown: stap 19, afbeelding 1 van 2 PSP 300x Teardown: stap 19, afbeelding 2 van 2
    • Unlock and remove one last ribbon cable from the bottom edge of the PSP.
    • Remove the screw from the bottom left corner of the PSP.
  20. PSP 300x Teardown: stap 20, afbeelding 1 van 2 PSP 300x Teardown: stap 20, afbeelding 2 van 2
    • Lift the silver rim on the right side of the PSP up and off.
    • Lift the silver rim on the left side of the PSP up and off.
  21. PSP 300x Teardown: stap 21, afbeelding 1 van 3 PSP 300x Teardown: stap 21, afbeelding 2 van 3 PSP 300x Teardown: stap 21, afbeelding 3 van 3
    • Lift the motherboard up slowly starting from the bottom of the PSP, being careful not to damage the port on top.
    • Pull the motherboard out and remove it from the PSP.
    • The specific motherboard model of this PSP-3000 is TA-090
  22. PSP 300x Teardown: stap 22, afbeelding 1 van 2 PSP 300x Teardown: stap 22, afbeelding 2 van 2
    • On the top of the back of the PSP, pull the white plastic piece out.
    • Pull the spring out and remove it from the PSP.
  23. PSP 300x Teardown: stap 23, afbeelding 1 van 3 PSP 300x Teardown: stap 23, afbeelding 2 van 3 PSP 300x Teardown: stap 23, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Open the UMD (disk drive) and locate the two small black rubber squares wedged in the space between the casing and the metal drive hinge on either side.
    • Pull these out using a pair of tweezers.
  24. PSP 300x Teardown: stap 24, afbeelding 1 van 2 PSP 300x Teardown: stap 24, afbeelding 2 van 2
    • Remove the metal piece from the drive.
    • Grabbing the PSP with both hands, gently pinch the UMD lid towards the right side (the side without the battery).
    • Pull up and the the left side carefully to remove the lid from the PSP. (The casing may have to flex a little bit to allow this)
  25. PSP 300x Teardown: stap 25, afbeelding 1 van 2 PSP 300x Teardown: stap 25, afbeelding 2 van 2
    • Remove the four screw from the UMD drive.
    • Remove the drive.
  26. PSP 300x Teardown: stap 26, afbeelding 1 van 3 PSP 300x Teardown: stap 26, afbeelding 2 van 3 PSP 300x Teardown: stap 26, afbeelding 3 van 3
    • Enjoy the eye-candy.
mbnewsom
3.283 Reputatie
11 handleidingen geschreven
9 opmerkingen
Can you get me in pdf
Aayush - Antwoord
Does a PSP have any bearings inside of it?
Brooke Payne - Antwoord
No ball bearings. Thumbsticks are probably just Lubed plastics rubbing against eachother
mahonen -
Thank you very much for the guide.
C. JONES - Antwoord
This has inspired me to build my own PSP. I had one as a child, and want one now for the nostalgia. Thanks!
Sheenyl Hassan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 34
Afgelopen 7 dagen: 272
Afgelopen 30 dagen: 1,234
Altijd: 99,028
