In today's teardown, we will be cracking open the white plastic dock that came with the Original iPhone. The dock works only with the original iPhone. However, by removing the top cover of the dock, you can use the dock with other Apple products that have a 30 pin connector. In this teardown, you can modify the dock to be universal.
WARNING: THIS DISASSEMBLY WILL VOID YOUR DOCK'S WARRANTY.
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je iPhone 1st Generation Dock te repareren, gebruik onze reparatiehandleidingen.
