Inleiding
I was browsing my attic for a teardown idea, but somehow found my old, non-working Nokia 2. Nokia 2 is a budget phone that has the lowest specs.
Open the back casing with your fingernail or a plastic pick.
Unscrew the seven screws with your T5 screwdriver.
These screws should be removed with your T2 screwdriver.
Use a spudger or anything that is thin and sturdy (not a piece of paper).
Take your tool and place between the back cover and the device. Lift the tool until the motherboard is exposed.
This is the motherboard.
This is the big mammoth, the 4000mAH battery.
This is where our charging module sits.
This is the speaker itself.
This is where the Taptic Engine resides.
Before the moment of truth, let's detach more cables.
Use the spudging tool (used on step 5), Remove the battery from the slit shown and cut it.
The green marks the 1GB RAM made by SK hynix
The red marks the Qualcomm Snapdragon 212. Unfortunately, this chip only supports ARMv7 so you can only play a little bit of games
