Disassembling the remote requires removing screws under the batteries.Removing anything inside will require caution and time .
Deze demontage is geen reparatiehandleiding. Om je Nintendo Wii Remote te repareren, gebruik onze reparatiehandleidingen.
To fully take off the back piece you will have to use your flat head screw driver and gently go along the edge and unclip it.
Gently pull out the whole circuit board ( be careful you may break or rip a wire if you pull to hard )
{CAUTION :WATCH OUT FOR SMALL PARTS}
To remove the buttons you will simply have to take off the grey silicon cover.
To remove the small speaker you can simply pull up .
CAUTION : FOR SMALLER BUTTONS LIKE THE VOLUME ONES .
Gently pry the buttons upwards ,removing the buttons from its holding slot.
CAUTION : WATCH OUT FOR SMALL BUTTONS !
IF YOU WANT TO REBUILD IT FOLLOW STEPS 1-7 BACKWORDS.
Deze handleiding insluiten
Kies een formaat en kopieer de code hieronder om deze handleiding als een kleine widget op je website of forum in te sluiten.
Voorbeeld
