Gereedschappen die in deze demontage worden gebruikt
Inleiding
Oh Happy Joy! It's here! The Nintendo DSi XL for all to see! Whoopee! Join us for an exciting teardown into the innards of this behemoth of a DSi.
Also check out the video slideshow of the teardown!
The Nintendo DSi XL is the latest iteration of Nintendo's ever-popular handheld gaming console, the Nintendo DS.
Along with fancy new packaging, the new features include:
Two screens that are 93% proportionally bigger than those found in the DS Lite.
A new full size stylus for added precision on larger screens.
The DSi XL measures in at 161 x 91.4 x 21.2 mm and weighs in at a whopping 314 g. That's 45% heavier than the 217 g DSi.
Side by side comparison of the DSi (left) and DSi XL (right).
The featured specs of the DSi XL are the twin 4.2" LCD panels.
The back side of the DSi XL. What a surprise! It's made in China.
Nintendo provided quite a hefty upgrade in battery size from 840 mAh in the DSi (Right) to 1050 mAh in the DSi XL (Left).
For all you math haters out there, that's 25% more capacity!
Larger capacity comes with the cost of more weight. The XL's battery weighs 23 g compared to the 19 g DSi battery.
Pry the following connectors straight up using the flat end of a spudger:
SD board cable connector
Volume control cable connector
Thankfully, Nintendo designed the DSi XL to eliminate a long ribbon cable spanning the width of the old DSi.
Four red plastic covers need to be removed to reveal the Phillips screws underneath.
Removing the four Phillips screws allows access to the top display.
Push the top outer case toward the top edge of the DSi XL, then use a spudger to pry it off the clips holding it to the inner case.
Use a spudger to pry the outward facing camera from its resting place on the top outer case.
Remove the single Phillips screw securing the inward facing camera's bracket to the top inner case.
Carefully pull the camera ribbon cable through the hollow right hinge, being careful not to rip it or the display ribbon cable.
The DSi XL has two digital cameras; one on the internal hinge pointed toward the user and the other pointed away from the top outer case.
Samsung and Fujitsu chips are identical to the DSi:
Samsung 1st generation MoviNAND KMAPF0000M: 256 MB NAND Flash and MMC controller. The integrated MMC controller allows the CPU to offload the complex work of directly talking to the flash memory.
82DBS08164D-70L: Fujitsu Ltd 128-bit FCRAM (fast-cycle RAM) chip.
TI (TXN) 72071B0 power managing and charging circuit. This used to be a Mitsumi chip in the smaller DSi.
PAIC3005B: We assume it stands for Primary Antenna Interface Controller, given that it's located right by the antenna.
Primary Nintendo ARM CPU, manufactured the last week of 2009. This chip's markings are identical to the DSi. It's definitely not the Tegra chip that had been rumored.
Here's a couple of large photos of the front and back of the logic board. Warning for 56K users: we mean large.
6 Opmerkingen
The 4 screws at the bottom corners are covered by something ans I cant' get the battery out. If there's some procesure to doing this please tell me.
You should be able to pry the rubber feet at the corners out with an Xacto knife or a small flathead screwdriver.
As for the battery, you should be able to get it out by putting your fingernail or a flathead under the the small ridge at the end closest to the charger port and then pulling upwards.
thanx now i can change the buttons
how much is one battery
Is there something I must know not to touch if I want to change the D-Pad?
