Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je NES Classic Edition te repareren, gebruik onze reparatiehandleidingen.
  1. Nintendo Classic Mini NES Teardown, Nintendo Classic Mini NES Teardown: stap 1, afbeelding 1 van 3 Nintendo Classic Mini NES Teardown, Nintendo Classic Mini NES Teardown: stap 1, afbeelding 2 van 3 Nintendo Classic Mini NES Teardown, Nintendo Classic Mini NES Teardown: stap 1, afbeelding 3 van 3
    • More than 30 years after the release of the original NES console, Nintendo delights us with a fun-sized version of this classic.
    • This little emulator box comes along with:
    • 30 pre-installed games
    • HDMI output
    • USB port for power support
    • 1 game controller
    • Just for fun we compared a classic cartridge to this Classic Edition—they're roughly the same size. How far computers have come!
  2. Nintendo Classic Mini NES Teardown: stap 2, afbeelding 1 van 2 Nintendo Classic Mini NES Teardown: stap 2, afbeelding 2 van 2
    • It's playtime! We ignore the warnings about extended gaming and start opening this treasure up.
    • We peel off some rubber feet and find standard, simple Phillips screws.
    • Lifting off the lower case, we take a look into the lid and find—nothing.
  3. Nintendo Classic Mini NES Teardown: stap 3, afbeelding 1 van 3 Nintendo Classic Mini NES Teardown: stap 3, afbeelding 2 van 3 Nintendo Classic Mini NES Teardown: stap 3, afbeelding 3 van 3
    • Turns out everything is secured in the lower case, and "everything" isn't all that much.
    • We immediately start punching through cables.
    • You heard that right, Mario may look like he's head bopping those blocks, but it's actually his fist!
    • A grand total of three connectors (button board, controller 1, and 2) later: Level 1 complete!
  4. Nintendo Classic Mini NES Teardown: stap 4, afbeelding 1 van 3 Nintendo Classic Mini NES Teardown: stap 4, afbeelding 2 van 3 Nintendo Classic Mini NES Teardown: stap 4, afbeelding 3 van 3
    • The motherboard is secured under a nice metal shield, likely for heat dissipation and probably structural support.
    • De-shielded we see the mighty fields of... wait these look like chips we've seen before.
    • Allwinner R16 quad core ARM Cortex A7 processor with a Mali-400MP2 GPU core
    • 512 MB of Macronix MX30LF4G18AC 4 Gb NAND Flash memory (as opposed to the Spansion branded memory found in the SNES)
    • 256 MB of SK hynix 2 Gb DDR3 SDRAM (H5TQ2G63GFR-RDC)
    • X-Powers AXP223 Power Management IC
    • Richtek RT7295A 3.5 A synchronous step-down converter
  5. Nintendo Classic Mini NES Teardown: stap 5, afbeelding 1 van 3 Nintendo Classic Mini NES Teardown: stap 5, afbeelding 2 van 3 Nintendo Classic Mini NES Teardown: stap 5, afbeelding 3 van 3
    • While the console only comes with one controller, you've got the classic Player 2 option available. At least until we remove these ports!
    • The ports are the same as the one on the Wii Remote. So you can connect your Wii Classic Controller to the NES Classic.
    • As you may have guessed, these ports are updated from the controller ports of the original NES and Famicom units.
    • We know the standard "blow on it" fix doesn't always work, so we're happy to see modularity here. Unfortunately, the USB and HDMI ports were both soldered to the motherboard.
  6. Nintendo Classic Mini NES Teardown: stap 6, afbeelding 1 van 2 Nintendo Classic Mini NES Teardown: stap 6, afbeelding 2 van 2
    • The final countdown brings us to: the button assembly!
    • This self-proclaimed daughterboard contains the (nicely labeled) power and reset button, as well as a status LED.
    • Notably missing from this console is the expansion port found in the original model. Since it never got used in the original consumer edition, probably safe to say we're not missing out on much.
  7. Nintendo Classic Mini NES Teardown: stap 7, afbeelding 1 van 3 Nintendo Classic Mini NES Teardown: stap 7, afbeelding 2 van 3 Nintendo Classic Mini NES Teardown: stap 7, afbeelding 3 van 3
    • And now for the bonus level: controller teardown!
    • The screws on this controller are readily visible, no rubber plugs here. Inside we find: a bare board with a single connector.
    • The cable is nicely threaded inside to allow some slack, to relieve stress on the connector.
    • The front side of the board is almost as bare. A single chip, some passive components, and some contact patches for the buttons.
    • These buttons act just like many remote controls, when pressed, the button bridges the gap between the conductive paint, completing a circuit—making Mario do something cool!
  8. Nintendo Classic Mini NES Teardown: stap 8, afbeelding 1 van 1
    • That's all there is! While there aren't many components, there are definitely more than 8 bits.
    • Okay, we admit, that was a pretty dumb joke.
  9. Laatste gedachten
    • Only standard Phillips screws are used.
    • No breakable plastic clips or strong adhesive is used.
    • Many components are modular including the button board and controller ports.
    • The NES Classic ships with solid state games, this reduces the wear on the device, but means upgrades are probably not an option.
    • The HDMI and USB ports are soldered to the mainboard which makes for a more complicated repair.
    Repareerbaarheidsscore
    8
    Repareerbaarheid 8 op 10
    (10 is gemakkelijkst te repareren)
Tobias Isakeit
117.588 Reputatie
188 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
11 opmerkingen
It would be nice to see a teardown comparison to the original NES.
Tim Briscoe - Antwoord
I agree completely. <3
Samantha Tigerlily -
Upgrades are definitely an option! Additional games can be flashed to the system via an app, game roms, a USB cable and a PC. Because of this, the orange minus icon, should be changed to a green checkmark.
Stephen Harbin - Antwoord
It is not intended by Nintendo to add games but it is definitely possible (I also flashed some extra games on it). The manufacturer does not offer any software for editing, therefore it is not red, but orange :)
Tobias Isakeit -
No picture of the back?
Sam Cornwell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 224
Altijd: 36,434
