Ga door naar hoofdinhoud
Wat je nodig hebt
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je New Nintendo 2DS XL te repareren, gebruik onze reparatiehandleidingen.
    Laatste gedachten
    • The battery is fairly easy to swap out once you remove the back cover.
    • The rear panel is secured by tri-point screws.
    • The headphone jack and charging connector are soldered to the motherboard.
    • The upper display is glued in place and requires prying that can potentially break the display.
    Repareerbaarheidsscore
    4
    Repareerbaarheid 4 op 10
    (10 is gemakkelijkst te repareren)
18 opmerkingen
yet another yootoob tear-down...why? whats wrong with the others - some peeps cant get to yootoob during the day!
P Stephenson - Antwoord
Any idea how I can get my hands on a replacement back frame. I found a crack in the bottom right corner.
Nathaniel Canning - Antwoord
Why can’t i find a direct 2ds close upper screen replacement? Is it the same screen as the 3Ds Xl?
John - Antwoord
It’s not the same, the 2DS screen is in 2D and the 3DS has a 3D screen
Liam Judge -
Warning!
In the teardown video they show how to remove the ribbon cable, but beware! Two of these cable dont have the regular easy fit where you lift the flick to get it open and remove the cable. (Yes, they do this in the video and brake it.) Once they’re open” they wont close again.
The cable right above the cart slot is ond and the closes cabel to the joystick is the other. (The two with the back connectors)
BEWARE!
I have not tested this yet but it seems as it is a tight push fit to these ribbon cables.
If there is so, please let other people know so they dont do the same mistake as i by opening it and cannot close it again.
In worst case your New 2DS XL turn on!
Daniel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 150
Afgelopen 30 dagen: 757
Altijd: 71,000
