Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Nikon Coolpix 3500 te repareren, gebruik onze reparatiehandleidingen.
  1. Nikon Coolpix 3500 Teardown, Nikon Coolpix 3500 Teardown: stap 1, afbeelding 1 van 1
    • Remove the battery cover.
    • Remove the battery.
  2. Nikon Coolpix 3500 Teardown: stap 2, afbeelding 1 van 1
    • Remove two 4.5 mm screws next to the battery slot.
    • Remove one 3 mm screw above the CF memory card slot.
    • Remove one 4.5 mm screw next to the CF memory card slot.
  3. Nikon Coolpix 3500 Teardown: stap 3, afbeelding 1 van 1
    • Remove two 4.5 mm screws from inside the battery slot.
  4. Nikon Coolpix 3500 Teardown: stap 4, afbeelding 1 van 1
    • Remove two 5 mm screws from the opposite end of the battery slot.
  5. Nikon Coolpix 3500 Teardown: stap 5, afbeelding 1 van 1
    • Remove the plastic cap and the 5 mm screw underneath.
  6. Nikon Coolpix 3500 Teardown: stap 6, afbeelding 1 van 1
    • Remove the five 3.5 mm screws from the bottom of the camera.
    • Gently pry off the grey faceplate.
    • Do not pull hard; there are two wires connecting the faceplate to the motherboard.
  7. Nikon Coolpix 3500 Teardown: stap 7, afbeelding 1 van 3 Nikon Coolpix 3500 Teardown: stap 7, afbeelding 2 van 3 Nikon Coolpix 3500 Teardown: stap 7, afbeelding 3 van 3
    • Use a spudger to disconnect the white-capped wire at the bottom of the camera.
    • Use a spudger to disconnect the orange-capped wire at the bottom of the camera and set the faceplate aside.
  8. Nikon Coolpix 3500 Teardown: stap 8, afbeelding 1 van 1
    • Disconnect the grey-capped wires from the motherboard.
    • Disconnect the blue wire attached to the green chip from the center of the motherboard.
  9. Nikon Coolpix 3500 Teardown: stap 9, afbeelding 1 van 2 Nikon Coolpix 3500 Teardown: stap 9, afbeelding 2 van 2
    • Remove the 3.5 mm screw from the motherboard next to the rotating lens.
    • Flip the motherboard and lens over to access the three wires on the back that connect to the LED screen.
  10. Nikon Coolpix 3500 Teardown: stap 10, afbeelding 1 van 2 Nikon Coolpix 3500 Teardown: stap 10, afbeelding 2 van 2
    • Disconnect the blue wire connecting the motherboard to the LED screen.
    • Disconnect the orange wire using a spudger while pushing out horizontally.
    • Disconnect the red capped wire from the motherboard.
    • Lift the motherboard and lens (still connected) out of the back case.
  11. Nikon Coolpix 3500 Teardown: stap 11, afbeelding 1 van 1
    • Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
  12. Nikon Coolpix 3500 Teardown: stap 12, afbeelding 1 van 1
    • Remove the 2.5 mm screw next to the red capped wire.
    • Remove the two 3.4 mm screws on the back of the directional buttons.
    • Remove the two 4.4 mm screws in the metal plate across from the orange wire.
  13. Nikon Coolpix 3500 Teardown: stap 13, afbeelding 1 van 2 Nikon Coolpix 3500 Teardown: stap 13, afbeelding 2 van 2
    • Gently lift the LED screen out of the remaining casing and set it aside.
    • Be careful not to let the rubber backing of the buttons fall out of place.
richard guenther
183 Reputatie
6 handleidingen geschreven
Cal Poly, Team 30-38, Garner Spring 2010 Lid van Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 7,758
