Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je Nexus 6P te repareren, gebruik onze reparatiehandleidingen.
  1. Remove SIM card tray. Remove SIM card tray.
    • Remove SIM card tray.
  2. Heat up back glass panel. Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel. The back glass panel is easily shattered and the adhesive underneath is fierce. So be careful to pry this part.
    • Heat up back glass panel.
    • Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel.
    • The back glass panel is easily shattered and the adhesive underneath is fierce. So be careful to pry this part.
    • Remove back glass panel carefully.
    A hair dryer works well for this part.
    Tara Zieminek - Antwoord
  3. Heat up bottom plastic panel. Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath. Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
    • Heat up bottom plastic panel.
    • Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
  4. Twist off 6 Phillips screws together. Insert guitar picks and plastic opening tool to separate front assembly from back cover. Attention: These two parts fit tightly.It is very difficult to separate them. You can also try using heavy-duty suction cup to disassemble them.
    • Twist off 6 Phillips screws together.
    • Insert guitar picks and plastic opening tool to separate front assembly from back cover.
    • Attention: These two parts fit tightly.It is very difficult to separate them. You can also try using heavy-duty suction cup to disassemble them.
  5. Unscrew one Phillips screw. Remove metal bracket securing flex contactors. Release 3 flex contactors and remove it .
    • Unscrew one Phillips screw.
    • Remove metal bracket securing flex contactors.
    • Release 3 flex contactors and remove it .
    • This flex is used to connect motherboard and daughterboard.
  6. Release battery contactor. The battery is fiercely glued in. Use plastic card to cut strong adhesive underneath, then pry up and remove battery.
    • Release battery contactor.
    • The battery is fiercely glued in.
    • Use plastic card to cut strong adhesive underneath, then pry up and remove battery.
    Be careful - there are cables underneath the battery that you can easily damage.
  7. Here we can see the strong sticker underneath 3450 mAh battery. Here we can see the strong sticker underneath 3450 mAh battery.
    • Here we can see the strong sticker underneath 3450 mAh battery.
  8. Disconnect signal cable contactor and twist off one Phillips screw. Remove daughterboard. Remove daughterboard.
    • Disconnect signal cable contactor and twist off one Phillips screw.
    • Remove daughterboard.
  9. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  10. Cut adhesive underneath vibration motor, then remove vibrator. Cut adhesive underneath vibration motor, then remove vibrator. Cut adhesive underneath vibration motor, then remove vibrator.
    • Cut adhesive underneath vibration motor, then remove vibrator.
  11. Twist off one Phillips screw and remove loudspeaker. Twist off one Phillips screw and remove loudspeaker. Twist off one Phillips screw and remove loudspeaker.
    • Twist off one Phillips screw and remove loudspeaker.
  12. Twist off 2 Phillips screws. Remove metal bracket securing front camera contactor and audio jack contactor,
    • Twist off 2 Phillips screws.
    • Remove metal bracket securing front camera contactor and audio jack contactor,
  13. Remove front camera. Remove front camera. Remove front camera.
    • Remove front camera.
  14. Remove audio jack. Remove audio jack.
    • Remove audio jack.
  15. Twist off 3 Phillips screws. Take away metal bracket securing LCD flex contactor. Release LCD flex connector.
    • Twist off 3 Phillips screws.
    • Take away metal bracket securing LCD flex contactor.
    • Release LCD flex connector.
  16. Remove signal cable. Remove signal cable.
    • Remove signal cable.
  17. Pry up and remove motherboard. Pry up and remove motherboard.
    • Pry up and remove motherboard.
  18. Remove fingerprint scanner. Remove fingerprint scanner. Remove fingerprint scanner.
    • Remove fingerprint scanner.
  19. Remove rear camera. Remove rear camera. Remove rear camera.
    • Remove rear camera.
  20. Here is the motherboard. Here is the motherboard.
    • Here is the motherboard.
  21. Remove earpiece. Remove earpiece.
    • Remove earpiece.
  22. The sticker underneath LCD with digitizer is a little bit strong, so use heat gun to soften it for a few minutes. With the help of suction cup, plastic opening tool and guitar picks, remove LCD assembly carefully. With the help of suction cup, plastic opening tool and guitar picks, remove LCD assembly carefully.
    • The sticker underneath LCD with digitizer is a little bit strong, so use heat gun to soften it for a few minutes.
    • With the help of suction cup, plastic opening tool and guitar picks, remove LCD assembly carefully.
  23. Done.
    • Done.
Witrigs
65.243 Reputatie
386 handleidingen geschreven
good jod !buddy
Kaye - Antwoord
Does the Nexus 6P have two antennas? I've noticed there's a two sim card slots?
sam34866 - Antwoord
Its single sim slot sorry
Noorulla Shariff -
Ya its haveing to sim slot but there is only 1 antina
Noorulla Shariff - Antwoord
There is a thin lining of plastic around the screen. Does removing it deteriorate the structural integrity of the screen or is it simply cosmetic?
Sorry if this is the wrong place to ask.
Eric Jensen - Antwoord
Yes, much like the iPhones. If the plastic becomes lose, the screen will be loose, as it acts as a spacer,
Adam99 -
The first time I replaced a Nexus 6P battery, everything worked fine.
The second time, the “Signal Cable” in step 15 was damaged and now the screen appears to be damaged (it still vibrates in response to touch events but is not displaying anything). Is it possible to replace this without replacing the screen?
After replacing the digitizer and the battery, my proximity sensor stopped working. Can you show with a diagram where this part is? I am assuming that it’s the black plastic piece attached to the motherboard on step 19 right next to the camera. Why would it stop functioning? Could it be that something has gotten in its way?
Marcel Ferreira - Antwoord
What if you just want to replace the broken glass??
justine mendoza - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 19,428
