Ga door naar hoofdinhoud
Wat je nodig hebt
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je Motorola Moto X 1st Generation te repareren, gebruik onze reparatiehandleidingen.
  1. Motorola Moto X Teardown, Motorola Moto X Teardown: stap 1, afbeelding 1 van 2 Motorola Moto X Teardown, Motorola Moto X Teardown: stap 1, afbeelding 2 van 2
    • The love child of Motorola and Google is here, and we are dying to crack open the little Motoroogle.
    • Technical Specifications:
    • Dual-core 1.7 GHz Qualcomm Snapdragon S4 Pro processor
    • 2 GB RAM
    • 4.7-inch 1280x720 pixels AMOLED display
    • 16 or 32 GB internal storage
    • Qualcomm Adreno 320 GPU
    • 10 MP rear-facing camera
  2. Motorola Moto X Teardown: stap 2, afbeelding 1 van 3 Motorola Moto X Teardown: stap 2, afbeelding 2 van 3 Motorola Moto X Teardown: stap 2, afbeelding 3 van 3
    • The top of the Moto X houses the centered headphone jack. We haven't seen this placement on too many recent smartphones.
    • Does it make more sense than a headphone jack on the bottom of a phone? Only time will tell…(but yes, it probably makes more sense).
    • Since we tend to have a lot of devices laying around, we might as well do some comparisons! The Moto X is certainly not small, but it is a bit smaller than the S4, and we are fans of the contoured back.
    • This is the first and only smartphone that's "Designed & Assembled in the USA," to our knowledge.
  3. Motorola Moto X Teardown: stap 3, afbeelding 1 van 2 Motorola Moto X Teardown: stap 3, afbeelding 2 van 2
    • Our Moto X has a small defect next to the SIM card tray. Hmmmm...
    • Hopefully this sort of flaw will be limited to the first run phones, and my custom teal model will be made with a little more care.
    • Using the fancy SIM eject tool provided by Motoroogle, we remove the SIM card tray from the side of the device.
    • We're interested to see the internal layout of this device, with so many components lined up along the center.
  4. Motorola Moto X Teardown: stap 4, afbeelding 1 van 2 Motorola Moto X Teardown: stap 4, afbeelding 2 van 2
    • Snap snap SNAP!
    • The melodious sound of easy teardown access fills our ears as we release clips holding the rear panel in place.
    • What is this? Google! Motorola! How could you do this to us?
    • To our dismay, the unexpectedly flexible rear panel, though clipped to the device, is also adhered. Time to bring in some reinforcements.
    *note* If you don't use a wide prying tool (Like the one in the picture), you will likely crack the outside edge of the back cover.
    Jason Ross - Antwoord
    Fake rubbery carbon back cover is harder to remove than the stiffer pink back cover variant:
    It uses two layers of glue in between a silicon buffer, the glue pad on the outer side sticks way better to the rubber than the layer that adheres to the nfc antenna/battery. Danger here is the connecting element for the camera flash being sandwiched here also,
    is more fragile during the removal (due to bendiness) at weak points like the volume buttons and the first points near the SIM slot. Make sure the glue got warm enough.
    Adrian Koch - Antwoord
  5. Motorola Moto X Teardown: stap 5, afbeelding 1 van 2 Motorola Moto X Teardown: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    iOpener
    $19.99
    Koop
    • Designed to penetrate the impenetrable, to de-here the adhered, to unfasten the hard-fastened, the iOpener has yet to meet gobs of adhesive it couldn't handle.
    • OEMs please take note, this is not a challenge…
    • Whilst removing the rear panel, we get our first glimpse at the NFC antenna.
    Obviously the phone you tore down was saturated with glue... but I don't think they all are. I've torn down 5-6 of these devices and not run into the glue yet (the back just pops off super clean and easy). The phones I attacked were couple of custom colored ones from the online store and a handful of "developer edition phones". Maybe the glue is just on the stock / mass produced variant?
    Josh Thomas - Antwoord
    I had a first run version and it had lots of adhesive just like their teardown model.
    Jason Ross -
  6. Motorola Moto X Teardown: stap 6, afbeelding 1 van 3 Motorola Moto X Teardown: stap 6, afbeelding 2 van 3 Motorola Moto X Teardown: stap 6, afbeelding 3 van 3
    • Even after defeating Big Blue, the rear panel still does not yield.
    • We release the ZIF connector of a big ol' rear-case-mounted flash assembly, and after 6 full steps, we are finally into the device.
    • Our guess is that the adhesive pad was added to make the phone feel more solid than one purely secured with clips. The pad also keeps the flash firmly in place, and may act as as padding to protect internal components.
    • Our "Woven Black" case has a nice weave. While it's probably not actual kevlar fibers, the molding makes for a nice view — you can see right through it!
  7. Motorola Moto X Teardown: stap 7, afbeelding 1 van 2 Motorola Moto X Teardown: stap 7, afbeelding 2 van 2
    • The pattern of these NFC coils triggers some powerful nostalgia.
    • The good ol' days of slot car bliss. Back when toy cars were as easy to drive as Autopia racers. Hold down a button. Watch them race around for hours and hours. Ahh…
    • Snap back to reality, there go the volume and sleep buttons, all on one handy cable.
    I miss my slot cars! Kids today have no idea how cool it was to start out with a basic one and step up to customizing everything, from motor to gear ratio, and to get crazy with a custom painted molded chassis.
    Those were the days. Tiger milk!
    Joe Schneider - Antwoord
  8. Motorola Moto X Teardown: stap 8, afbeelding 1 van 3 Motorola Moto X Teardown: stap 8, afbeelding 2 van 3 Motorola Moto X Teardown: stap 8, afbeelding 3 van 3
    • "We'll just wrestle this battery off here…Or not."
    • Time to chase down the end of the NFC antenna ribbon cable.
    • We interrogate the antenna assembly about the whereabouts of the cable's end. Nothing like a 54 Bit Driver Kit to encourage stubborn hardware.
    • Eureka! Adios, battery!
    What´s the size of the torx screws?
    Domingo Echenique - Antwoord
    This is a teardown, not meant to be followed for repairs. Check out the Moto X device page for step-by-step repair guides and more detail, like the sizes of certain screws!
    Sam Goldheart -
  9. Motorola Moto X Teardown: stap 9, afbeelding 1 van 1
    • Motorola claims the Moto X battery can power through an amazing 24 hours of "mixed usage."
    • How does the Moto X accomplish such a feat with a 3.8 volt, 2200 mAh Lithium ion battery? The secret is in the X8 Mobile Computing System.
    • The Motorola X8 Mobile Computing System is comprised of a Qualcomm Snapdragon S4Pro family processor, a natural language processor and a contextual computing processor.
    • Motorola developed a custom system architecture, which, when coupled with eight processor cores, allows for the delegation of processing power:
    • 4 graphics processor cores for "stunning clarity"
    • 2 application processor cores for "swift action"
    • 2 low-power cores—"awaiting your next command"
  10. Motorola Moto X Teardown: stap 10, afbeelding 1 van 3 Motorola Moto X Teardown: stap 10, afbeelding 2 van 3 Motorola Moto X Teardown: stap 10, afbeelding 3 van 3
    • Out comes the upper midframe panel, housing the speaker, headphone jack, more antennas, and pressure contacts.
    • Yay, pressure contacts! We like spring pressure contacts because they don't require any work to disconnect.
    • This is possibly the most modular headphone jack we've ever seen. It pops right out of the upper midframe panel, spring contacts and all.
  11. Motorola Moto X Teardown: stap 11, afbeelding 1 van 3 Motorola Moto X Teardown: stap 11, afbeelding 2 van 3 Motorola Moto X Teardown: stap 11, afbeelding 3 van 3
    • A spudger helps us unclip a small microphone board from the earpiece speaker.
    • The microphone assembly clings (like a baby sloth) to the earpiece speaker to maintain a solid connection with the spring contacts below.
    • Naturally, we love design innovation. We can tell that a considerable amount of effort went in to the internal design of this device; the number of clips and contacts we've found so far is a great testament to that.
  12. Motorola Moto X Teardown: stap 12, afbeelding 1 van 3 Motorola Moto X Teardown: stap 12, afbeelding 2 van 3 Motorola Moto X Teardown: stap 12, afbeelding 3 van 3
    Precision Tweezers Set
    $9.95
    Koop
    • After selecting our favorite pair of precision tweezers, we remove the 2 MP front-facing camera from the Moto X.
    • The front-facing camera is labeled as 84016172 REV A 0054067 01017429 142-3.
  13. Motorola Moto X Teardown: stap 13, afbeelding 1 van 2 Motorola Moto X Teardown: stap 13, afbeelding 2 van 2
    Soldering Workstation
    $49.99
    Koop
    • The motherboard is ours for the taking, and take we will. Let's just hope there's a little more excitement on the other side of the board.
    • Alas, the streets of this circuit city are looking a little bare. We're going to guess there's a lot more fun to be found under the myriad EMI shields. Only one way to find out…
  14. Motorola Moto X Teardown: stap 14, afbeelding 1 van 2 Motorola Moto X Teardown: stap 14, afbeelding 2 van 2
    • Before we can fully examine the motherboard, though, we must remove the 10 megapixel rear-facing camera.
    • 10 MP is 25% more pixels than the camera in the iPhone 5, but isn't quite on the Lumia 1020's level, though we can hardly fault it for that.
    How do you guys remove the EMI shield so neatly?
    Alisio - Antwoord
  15. Motorola Moto X Teardown: stap 15, afbeelding 1 van 1
    • Notable ICs on the motherboard:
    • Toshiba THGBMAG7A2JBAIR 16 GB eMMC NAND Flash
    • SK Hynix H9TKNNNBPDAR RAM (we assume that the Snapdragon S4 Pro is also layered under this IC)
    • Qualcomm PM8921 Power Management IC
    • Texas Instruments TMS320C55 Digital Signal Processor
    • NXP 44701 NFC Chip
    • Skyworks 77619-12 Multiband Multimode Power Amplifier Module for Quad-Band GSM / EDGE and Penta-Band (Bands I, II, IV, V, VIII) WCDMA/ HSDPA/ HSUPA/ HSPA+/ LTE
    • Texas Instruments MSP430 F5259 Mixed Signal Microcontroller
  16. Motorola Moto X Teardown: stap 16, afbeelding 1 van 1
    • Additional ICs:
    • Qualcomm WCD9310 Audio Codec
    • Qualcomm WCN3680 802.11ac Combo Wi-Fi/Bluetooth/FM
    • NXP TFA9890 High Efficiency Class-D Audio Amplifier
    • Skyworks 77737 SkyHi™ Power Amplifier Module for LTE Bands 12/17 (698-716 MHz)
    • EPCOS 7959 Wireless LAN/Bluetooth Filters (IF)
    • Qualcomm WTR16505L LTE/HSPA+/CDMA2K/TDSCDMA/EDGE/GPS Transceiver
  17. Motorola Moto X Teardown: stap 17, afbeelding 1 van 1
    • Teardown update: We got ahold of a Verizon version of the Moto-X and played a little game of 'spot the difference' with the motherboard:
    • SanDisk SDIN8DE2-16G 16 GB NAND Flash replaces the Toshiba
    • Samsung K3PE0E00QM-CGC2 2 GB LPDDR2 RAM instead of SK Hynix
    • The Verizon model adds another Qualcomm modem, the WTR1605 (in addition to the WTR1606L, possibly used solely for LTE support on this model)
  18. Motorola Moto X Teardown: stap 18, afbeelding 1 van 3 Motorola Moto X Teardown: stap 18, afbeelding 2 van 3 Motorola Moto X Teardown: stap 18, afbeelding 3 van 3
    • The back of the motherboard may look bare, but upon closer inspection we found two microphones:
    • Wolfson Microelectronics WM7121 Top Port Analogue Silicon Microphone
    • Wolfson Microelectronics WM7132 Bottom Port Analogue Silicon Microphone
    • Motoroogle again shows off its novelty; the X's vibrator motor is soldered right to the motherboard. The wonders never cease.
    • Like any good warrior, we hold onto the ears EMI shields of our enemies.
    It's interesting that the vibrator motor is rigidly attached to the PCB and is next to the camera. Many Moto X's develop a problem that makes the camera stop working over time. Is there a connection? (or should I say, a loose connection?)
    waldo - Antwoord
  19. Motorola Moto X Teardown: stap 19, afbeelding 1 van 2 Motorola Moto X Teardown: stap 19, afbeelding 2 van 2
    • The mobo is no mo', and we get to examine the backside of the display assembly, which is adorned by some nice comfy foam.
    • One thing about this device is certain: the design choices are nothing if not unique. The midframe is held in place by pins protruding from the edges of the display assembly bezel.
    How to disassemble frame from the display module assembly?
    Do I need any special tool?
    palyanitsin - Antwoord
  20. Motorola Moto X Teardown: stap 20, afbeelding 1 van 2 Motorola Moto X Teardown: stap 20, afbeelding 2 van 2
    The front glass is insert molded with plastic
    Neo - Antwoord
    Don't buy the replacement glass only from ebay, buy the glass + frame. You will see that the glass only has a "lip" for the plastic mold to mold over, which is something most of us cannot do. Also, beware that the glass over the front camera, make sure it is NOT tinted before install... The one I got has "tint" over it, which is actually meant for the proximity sensor (IR)
    xusdf - Antwoord
    Glass+frame is the way to go if just the Glass is broken, but LCD and touch still work.
    You also don't need to disassemble it completely. Only open the bottom two torx screws, then heat up the glass and carefully remove the glass parts from the panel and frame. Pry off the the old frame but don't loose the bolts, you'll need them. Ebay frames+glass come without bolts.
    Adrian Koch -
  21. Motorola Moto X Teardown: stap 21, afbeelding 1 van 2 Motorola Moto X Teardown: stap 21, afbeelding 2 van 2
    • Motorola Moto X Repairability Score: 7 out of 10 (10 is easiest to repair)
    • Pressure contacts and cable connectors make the modular components (cameras, buttons, headphone jack and speakers) easy to replace.
    • The Moto X uses a single kind of screw, although it's a fairly uncommon size (T3).
    • The taped-in battery is less accessible than we'd like, but at least it's near the top of the stack once you get the rear cover off (as opposed to the HTC One).
    • The digitizer is fused to the display, increasing repair costs for a cracked screen. But the display midframe can be separated, potentially lowering the cost of the replacement part.
    • Sticky adhesive on the back cover is annoying and will slow opening the phone.
35 opmerkingen
what is the chip of GPS?
fabio - Antwoord
Confirmed, the WTR1605L is just to the right of the Toshiba memory, above the NXP NFC and TI MCU devices.
chipguyic -
Looks like Avago has LTE band 7 covered with the A5007 device. Just above the SKY77737 and to the left of the EPCOS WLAN/BT filters
chipguyic -
The GPS is likely integrated with the RF transceiver, but this device was not called out on the logic board. It is likely the WTR1605 part, given the other QCOM silicon contained within.
chipguyic - Antwoord
I saw the comment that no Samsung components but wondered if the display is made by them? I see SDM on the part numbers.
Jim Kell - Antwoord
Is there a touch controller IC? If so, who makes it?
chetk - Antwoord
Impressive teardown. Keep up the good work.
joeggarza - Antwoord
To your question "Does it make more sense than a headphone jack on the bottom of a phone? Only time will tell…(but yes, it probably makes more sense)." I strongly agree; I would suggest that it is much better to have the phone in your pocket with the earbud wire coming out the top than for the connector/wire to be bent/stressed down at the bottom of your pocket.
Bart - Antwoord
Thanks, but it not include as I can replace physical damage glass.
Could you extend this guide?
maximyual - Antwoord
can somebody tell me how to remove the emi shields that are soldered to the board?
2dspectre - Antwoord
Does anyone know where I can find the plastic/rubber gasket piece that sits over the proximity sensor. I've had the careless misfortune of losing not 1 but 2 of these during past services on this model, and have discovered them to be vital in the operation of the proximity sensor and thus the phone itself.
Jonathan Clifton - Antwoord
T3 screws on the upper frame are stripped, any suggestion to remove them?
xusdf - Antwoord
I filed a slot in them and used a straight screwdriver to remove.... might be hard to do with some of the screws that are down in holes.
Johnathan George -
Where is the photo memory chip on the motherboard??
katy - Antwoord
Hi who is the author of this as I would like to cite it and give a reference.
Nick - Antwoord
Wonder why they didn't connect or enable the radio chip so that users could utilize radio tuner onboard? I' told moto G has it, but my moto X (1st gen) does not.
Geo Sept 5, 2015
snodgrassg - Antwoord
So i tore mine down to replace the glass.. i think i missed something -0 because now it will do everything by make calls... screen goes black and no volume when call is made.
Any suggestions on what i'm missing?
Josh Hatcher - Antwoord
Is vibrator motor repairable/replacable ?
Recently I have been using it on vibration mode and now I think its damaged and it sounds weak and deteriorated.
umangajmera96 - Antwoord
Is it possible to change the internal memory from 16 GB up to 32 GB? I had a 32, it died. I bought a new one on eBay, but didn't notice that it's only a 16! It's full already, & I haven't even installed my SIM card yet!
jmkees1 - Antwoord
Do I need a T3 Torx or a T4 Torx to remove the eleven screws in order to replace the screen assembly? The new assembly was advertised with tools but they aren't the right size. >:( Everywhere I am looking is saying T4 Torx, but I have half the mind to think you are the accurate one. Can anyone confirm that the T3 is what I need to order?
andrew - Antwoord
Which antenna is the GPS antenna? My Moto X seems to show less GPS signal strength compared to others I have compared it to using same signal test app.
David Voight - Antwoord
My moto X won't charge anymore due to a broken uUSB charging connector. I believe the battery is just fine. Is the charging connector replaceble ?
benertle - Antwoord
I need the answer to this problem as well !! someone help ! The micro usb port on the motherboard doesn't look like it can be desoldered like other devices .
Ojasv Apurv -
Same here, my son uses my old developer edition.
Dennis Ross -
I bought a replacement battery but I noticed that don't include the NFC antenna, what would you recommend? I'm not sure if I could unstick the one that have my old battery. Also what would happen if I don't connect that antenna?
jspsaucedo - Antwoord
how for all parties ? I have only the motherboard
jimmycede28 - Antwoord
If I have a issue with WI-FI and bluetooth connectivity (hardware component failure). Can I replace only Qualcomm WCN3680 802.11ac IC.?
or I have to replace whole motherboard?
samarth kulkarni - Antwoord
Where is the Wireless Antenna located on the Moto X. I have replaced the lower antenna assembly, but that does not seem to fix my Wireless Antenna problem. My phone's wifi antenna is not working. it tries to connect, but then fails and keeps toggling between Connecting... and Saved connection.
Where is the Wifi Antenna located? What part needs to be replaced?
Ken Parker - Antwoord
Hey Ken. Ever figure out the answer to this? I'm having the same problem.
vlad.tamas -
How to notice my Moto x is genuine or it's a refurbished? Please inform me. Thank you.
Pritvi - Antwoord
Hi, anybody knows what is the number of the wifi ic module for MOTO X PLAY XT1563?
Eduardo Juarez - Antwoord
Hi, anybody knows what is the model number of the WIFI IC module for MOTO X PLAY XT1563?
I had to change the button’s flex cable but the new power button is not clicking right. How can I glue the flex cable to work it right?
werther - Antwoord
Is this possible in this model to turn on FM radio by rooting or the model's antenna is grounded ??
Hemant Sahu - Antwoord
hi, i need moto x and moto z force and moto z2 play shematic! please help me
moien - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 38
Altijd: 192,201
