Ga door naar hoofdinhoud
Wat je nodig hebt
Video overzicht
Deze demontage is geen reparatiehandleiding. Om je Motorola Moto X 1st Generation te repareren, gebruik onze reparatiehandleidingen.
  1. Motorola Moto X Teardown, Motorola Moto X Teardown: stap 1, afbeelding 1 van 2 Motorola Moto X Teardown, Motorola Moto X Teardown: stap 1, afbeelding 2 van 2
    • The love child of Motorola and Google is here, and we are dying to crack open the little Motoroogle.
    • Technical Specifications:
    • Dual-core 1.7 GHz Qualcomm Snapdragon S4 Pro processor
    • 2 GB RAM
    • 4.7-inch 1280x720 pixels AMOLED display
    • 16 or 32 GB internal storage
    • Qualcomm Adreno 320 GPU
    • 10 MP rear-facing camera
  2. Motorola Moto X Teardown: stap 2, afbeelding 1 van 3 Motorola Moto X Teardown: stap 2, afbeelding 2 van 3 Motorola Moto X Teardown: stap 2, afbeelding 3 van 3
    • The top of the Moto X houses the centered headphone jack. We haven't seen this placement on too many recent smartphones.
    • Does it make more sense than a headphone jack on the bottom of a phone? Only time will tell…(but yes, it probably makes more sense).
    • Since we tend to have a lot of devices laying around, we might as well do some comparisons! The Moto X is certainly not small, but it is a bit smaller than the S4, and we are fans of the contoured back.
    • This is the first and only smartphone that's "Designed & Assembled in the USA," to our knowledge.
  3. Motorola Moto X Teardown: stap 3, afbeelding 1 van 2 Motorola Moto X Teardown: stap 3, afbeelding 2 van 2
    • Our Moto X has a small defect next to the SIM card tray. Hmmmm...
    • Hopefully this sort of flaw will be limited to the first run phones, and my custom teal model will be made with a little more care.
    • Using the fancy SIM eject tool provided by Motoroogle, we remove the SIM card tray from the side of the device.
    • We're interested to see the internal layout of this device, with so many components lined up along the center.
  4. Motorola Moto X Teardown: stap 4, afbeelding 1 van 2 Motorola Moto X Teardown: stap 4, afbeelding 2 van 2
    • Snap snap SNAP!
    • The melodious sound of easy teardown access fills our ears as we release clips holding the rear panel in place.
    • What is this? Google! Motorola! How could you do this to us?
    • To our dismay, the unexpectedly flexible rear panel, though clipped to the device, is also adhered. Time to bring in some reinforcements.
  5. Motorola Moto X Teardown: stap 5, afbeelding 1 van 2 Motorola Moto X Teardown: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    iOpener
    $17.99
    • Designed to penetrate the impenetrable, to de-here the adhered, to unfasten the hard-fastened, the iOpener has yet to meet gobs of adhesive it couldn't handle.
    • OEMs please take note, this is not a challenge…
    • Whilst removing the rear panel, we get our first glimpse at the NFC antenna.
  6. Motorola Moto X Teardown: stap 6, afbeelding 1 van 3 Motorola Moto X Teardown: stap 6, afbeelding 2 van 3 Motorola Moto X Teardown: stap 6, afbeelding 3 van 3
    • Even after defeating Big Blue, the rear panel still does not yield.
    • We release the ZIF connector of a big ol' rear-case-mounted flash assembly, and after 6 full steps, we are finally into the device.
    • Our guess is that the adhesive pad was added to make the phone feel more solid than one purely secured with clips. The pad also keeps the flash firmly in place, and may act as as padding to protect internal components.
    • Our "Woven Black" case has a nice weave. While it's probably not actual kevlar fibers, the molding makes for a nice view — you can see right through it!
  7. Motorola Moto X Teardown: stap 7, afbeelding 1 van 2 Motorola Moto X Teardown: stap 7, afbeelding 2 van 2
    • The pattern of these NFC coils triggers some powerful nostalgia.
    • The good ol' days of slot car bliss. Back when toy cars were as easy to drive as Autopia racers. Hold down a button. Watch them race around for hours and hours. Ahh…
    • Snap back to reality, there go the volume and sleep buttons, all on one handy cable.
  8. Motorola Moto X Teardown: stap 8, afbeelding 1 van 3 Motorola Moto X Teardown: stap 8, afbeelding 2 van 3 Motorola Moto X Teardown: stap 8, afbeelding 3 van 3
    • "We'll just wrestle this battery off here…Or not."
    • Time to chase down the end of the NFC antenna ribbon cable.
    • We interrogate the antenna assembly about the whereabouts of the cable's end. Nothing like a 54 Bit Driver Kit to encourage stubborn hardware.
    • Eureka! Adios, battery!
  9. Motorola Moto X Teardown: stap 9, afbeelding 1 van 1
    • Motorola claims the Moto X battery can power through an amazing 24 hours of "mixed usage."
    • How does the Moto X accomplish such a feat with a 3.8 volt, 2200 mAh Lithium ion battery? The secret is in the X8 Mobile Computing System.
    • The Motorola X8 Mobile Computing System is comprised of a Qualcomm Snapdragon S4Pro family processor, a natural language processor and a contextual computing processor.
    • Motorola developed a custom system architecture, which, when coupled with eight processor cores, allows for the delegation of processing power:
    • 4 graphics processor cores for "stunning clarity"
    • 2 application processor cores for "swift action"
    • 2 low-power cores—"awaiting your next command"
  10. Motorola Moto X Teardown: stap 10, afbeelding 1 van 3 Motorola Moto X Teardown: stap 10, afbeelding 2 van 3 Motorola Moto X Teardown: stap 10, afbeelding 3 van 3
    • Out comes the upper midframe panel, housing the speaker, headphone jack, more antennas, and pressure contacts.
    • Yay, pressure contacts! We like spring pressure contacts because they don't require any work to disconnect.
    • This is possibly the most modular headphone jack we've ever seen. It pops right out of the upper midframe panel, spring contacts and all.
  11. Motorola Moto X Teardown: stap 11, afbeelding 1 van 3 Motorola Moto X Teardown: stap 11, afbeelding 2 van 3 Motorola Moto X Teardown: stap 11, afbeelding 3 van 3
    • A spudger helps us unclip a small microphone board from the earpiece speaker.
    • The microphone assembly clings (like a baby sloth) to the earpiece speaker to maintain a solid connection with the spring contacts below.
    • Naturally, we love design innovation. We can tell that a considerable amount of effort went in to the internal design of this device; the number of clips and contacts we've found so far is a great testament to that.
  12. Motorola Moto X Teardown: stap 12, afbeelding 1 van 3 Motorola Moto X Teardown: stap 12, afbeelding 2 van 3 Motorola Moto X Teardown: stap 12, afbeelding 3 van 3
    Precision Tweezers Set
    $9.95
    • After selecting our favorite pair of precision tweezers, we remove the 2 MP front-facing camera from the Moto X.
    • The front-facing camera is labeled as 84016172 REV A 0054067 01017429 142-3.
  13. Motorola Moto X Teardown: stap 13, afbeelding 1 van 2 Motorola Moto X Teardown: stap 13, afbeelding 2 van 2
    Soldering Workstation
    $49.99
    • The motherboard is ours for the taking, and take we will. Let's just hope there's a little more excitement on the other side of the board.
    • Alas, the streets of this circuit city are looking a little bare. We're going to guess there's a lot more fun to be found under the myriad EMI shields. Only one way to find out…
  14. Motorola Moto X Teardown: stap 14, afbeelding 1 van 2 Motorola Moto X Teardown: stap 14, afbeelding 2 van 2
    • Before we can fully examine the motherboard, though, we must remove the 10 megapixel rear-facing camera.
    • 10 MP is 25% more pixels than the camera in the iPhone 5, but isn't quite on the Lumia 1020's level, though we can hardly fault it for that.
  15. Motorola Moto X Teardown: stap 15, afbeelding 1 van 1
    • Notable ICs on the motherboard:
    • Toshiba THGBMAG7A2JBAIR 16 GB eMMC NAND Flash
    • SK Hynix H9TKNNNBPDAR RAM (we assume that the Snapdragon S4 Pro is also layered under this IC)
    • Qualcomm PM8921 Power Management IC
    • Texas Instruments TMS320C55 Digital Signal Processor
    • NXP 44701 NFC Chip
    • Skyworks 77619-12 Multiband Multimode Power Amplifier Module for Quad-Band GSM / EDGE and Penta-Band (Bands I, II, IV, V, VIII) WCDMA/ HSDPA/ HSUPA/ HSPA+/ LTE
    • Texas Instruments MSP430 F5259 Mixed Signal Microcontroller
  16. Motorola Moto X Teardown: stap 16, afbeelding 1 van 1
    • Additional ICs:
    • Qualcomm WCD9310 Audio Codec
    • Qualcomm WCN3680 802.11ac Combo Wi-Fi/Bluetooth/FM
    • NXP TFA9890 High Efficiency Class-D Audio Amplifier
    • Skyworks 77737 SkyHi™ Power Amplifier Module for LTE Bands 12/17 (698-716 MHz)
    • EPCOS 7959 Wireless LAN/Bluetooth Filters (IF)
    • Qualcomm WTR16505L LTE/HSPA+/CDMA2K/TDSCDMA/EDGE/GPS Transceiver
  17. Motorola Moto X Teardown: stap 17, afbeelding 1 van 1
    • Teardown update: We got ahold of a Verizon version of the Moto-X and played a little game of 'spot the difference' with the motherboard:
    • SanDisk SDIN8DE2-16G 16 GB NAND Flash replaces the Toshiba
    • Samsung K3PE0E00QM-CGC2 2 GB LPDDR2 RAM instead of SK Hynix
    • The Verizon model adds another Qualcomm modem, the WTR1605 (in addition to the WTR1606L, possibly used solely for LTE support on this model)
  18. Motorola Moto X Teardown: stap 18, afbeelding 1 van 3 Motorola Moto X Teardown: stap 18, afbeelding 2 van 3 Motorola Moto X Teardown: stap 18, afbeelding 3 van 3
    • The back of the motherboard may look bare, but upon closer inspection we found two microphones:
    • Wolfson Microelectronics WM7121 Top Port Analogue Silicon Microphone
    • Wolfson Microelectronics WM7132 Bottom Port Analogue Silicon Microphone
    • Motoroogle again shows off its novelty; the X's vibrator motor is soldered right to the motherboard. The wonders never cease.
    • Like any good warrior, we hold onto the ears EMI shields of our enemies.
  19. Motorola Moto X Teardown: stap 19, afbeelding 1 van 2 Motorola Moto X Teardown: stap 19, afbeelding 2 van 2
    • The mobo is no mo', and we get to examine the backside of the display assembly, which is adorned by some nice comfy foam.
    • One thing about this device is certain: the design choices are nothing if not unique. The midframe is held in place by pins protruding from the edges of the display assembly bezel.
  20. Motorola Moto X Teardown: stap 20, afbeelding 1 van 2 Motorola Moto X Teardown: stap 20, afbeelding 2 van 2
  21. Motorola Moto X Teardown: stap 21, afbeelding 1 van 2 Motorola Moto X Teardown: stap 21, afbeelding 2 van 2
    • Motorola Moto X Repairability Score: 7 out of 10 (10 is easiest to repair)
    • Pressure contacts and cable connectors make the modular components (cameras, buttons, headphone jack and speakers) easy to replace.
    • The Moto X uses a single kind of screw, although it's a fairly uncommon size (T3).
    • The taped-in battery is less accessible than we'd like, but at least it's near the top of the stack once you get the rear cover off (as opposed to the HTC One).
    • The digitizer is fused to the display, increasing repair costs for a cracked screen. But the display midframe can be separated, potentially lowering the cost of the replacement part.
    • Sticky adhesive on the back cover is annoying and will slow opening the phone.
35 opmerkingen
what is the chip of GPS?
fabio - Antwoord
Confirmed, the WTR1605L is just to the right of the Toshiba memory, above the NXP NFC and TI MCU devices.
chipguyic -
Looks like Avago has LTE band 7 covered with the A5007 device. Just above the SKY77737 and to the left of the EPCOS WLAN/BT filters
chipguyic -
The GPS is likely integrated with the RF transceiver, but this device was not called out on the logic board. It is likely the WTR1605 part, given the other QCOM silicon contained within.
chipguyic - Antwoord
I saw the comment that no Samsung components but wondered if the display is made by them? I see SDM on the part numbers.
Jim Kell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 38
Altijd: 192,693
