Deze demontage is geen reparatiehandleiding. Om je Motorola California Mobile Phone te repareren, gebruik onze reparatiehandleidingen.
Find a flat head or Phillips head screwdriver.
Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
Use the screwdriver to push the rods towards each other until they click out of their locked position.
Note: This may require a large amount of force.
Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
Remove the key guard from the rear casing by taking it out of its position.
Deze handleiding insluiten
Kies een formaat en kopieer de code hieronder om deze handleiding als een kleine widget op je website of forum in te sluiten.
Voorbeeld
