Inleiding
This Teardown can also be used as a disassembly or troubleshooting guide.
Wat je nodig hebt
Use your finger to press the button and free the device rear case.
slide the black button to free the battery so you can grab it with your other hand.
You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
The upper speaker is kept in place by a metal plate.
Use a metal spudger to free the 3 clips on the back side
