Gereedschappen die in deze demontage worden gebruikt
Begin by flipping your phone over so that the back cover is facing up.
Apply force to the back cover and simultaneously slide the cover down.
Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
On the top half of the phone push downwards on the number keys to free the keypad from the top of the phone.
Unhook the antenna by releasing the two hooks, one on each side of the phone.
Detach the antenna from the back of the circuit board
This small black rubber cover may detach.
Using your hands or the pry tool, gently lift the vibration mechanism out of the rear casing.
Unhook the 10 clips holding the metal screen cover in place and pull up to detach it from the logic board.
There are four clips at the top, two along each side, and two clips at the bottom of the metal cover.
List of Parts: Battery, SIM Card, Vibration mechanism, back cover, Front Case, Back Case, 2x rubber sides, 4x Screws, Antenna, Speaker, Keypad, Metal screen cover.
