Ga door naar hoofdinhoud
Gereedschappen die in deze demontage worden gebruikt
Inleiding
A mobile robot developed in the 80s by Tomy and sold by Radioshack in the United States.
More videos and information can be found at the I Heart Robotics blog
This guide shows a tear down of the main arm.
Deze demontage is geen reparatiehandleiding. Om je Mobile Armatron te repareren, gebruik onze reparatiehandleidingen.
  1. Open up the remote control. Open up the remote control. Open up the remote control.
    • Open up the remote control.
  2. Remove the screw as indicated. Remove the screw as indicated.
    • Remove the screw as indicated.
  3. If someone spilled soda or apple juice over the controller it may be helpful to clean the board using contact cleaner. If someone spilled soda or apple juice over the controller it may be helpful to clean the board using contact cleaner.
    • If someone spilled soda or apple juice over the controller it may be helpful to clean the board using contact cleaner.
  4. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  5. Remove screws where indicated.
    • Remove screws where indicated.
  6. Gripper components can be removed for further disassembly. Gripper components can be removed for further disassembly. Gripper components can be removed for further disassembly.
    • Gripper components can be removed for further disassembly.
  7. Use the knife to peel off stickers that conceal the screw holes. Use the knife to peel off stickers that conceal the screw holes. Use the knife to peel off stickers that conceal the screw holes.
    • Use the knife to peel off stickers that conceal the screw holes.
  8. More screws can be removed to check the condition of gear teeth. Admire the mechanical design. Admire the mechanical design.
    • More screws can be removed to check the condition of gear teeth.
    • Admire the mechanical design.
I Heart Robotics
210 Reputatie
3 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 13
Afgelopen 30 Dagen: 18
Altijd: 10,277
