Inleiding
We picked up our new MacBook Pro at the local Apple Store this morning. We practically mugged the Fedex delivery guy on the way in to the building, and we got the first box off the pallet.
Wat je nodig hebt
The new, 37 percent friendlier-to-squirrels and tree-frogs MacBook Pro box. Yay for pallet density! Oh, and it's heavier than it looks.
Follow our updates on twitter.
New, rounded bottom. And a much darker plastic wireless window.
In the box:
Citaat van keb:
What is the purpose of the "wireless window" on the back of my 15" unibody?
Apple calls it a 'clutch cover,' but essentially it is just a cosmetic cover to hide the AirPort card, antenna board, and the hinges housed in the display. It is made of plastic presumably to allow for the passage of signals to/from your AirPort card.
Ports, left to right:
MagSafe Power Port
Gigabit Ethernet Port
Firewire 800 Port (FW 400 with optional cable)
USB Port X2
Mini DisplayPort
Audio Line-in , Audio Line-out
ExpressCard/34 Slot
Remove one Phillips screw to release the hard drive bracket. The screw is held captive to the bracket.
Remove the four T6 screws securing the hard drive.
Replacing the hard drive is significantly easier on this machine than the previous MacBook Pro.
This machine uses the same, industry standard SATA notebook drives as previous MacBook Pro and MacBook models.
Shameless plug: Of course, you can upgrade the hard drive in any Apple laptop. We have free guides for every model that makes hard drive replacement easy.
Kudos to Apple for making this easy. Keeping repair costs down is probably the most environmentally friendly thing Apple has done with this machine.
Citaat van nicole3:
what type hard drive is apple using?
SATA
Citaat van sean70:
Is there an available internal USB port connection? Can one be added somewhat easily? I couldn't get a detailed enough view on Photo 20...
Not that we ran across and Apple does not have any official documentation indicating the presence or lack of internal USB.
Something is missing from this step. There is a Philips screws that secures the plastic bracket to the hard drive. Need a Philips #00 to remove it. Then remove the 4 Torx-6 screws on the side of the hard drive and re-use them on the new hard drive (if you're replacing the hard drive).
Citaat van IFlyX5:
Take a gander at our MacBook Pro 15" Unibody guides for detailed disassembly instructions.
The first step to opening this machine is removing the bottom plate.
Remove the following 8 screws:
Let's see what's creating all that torsional rigidity that Jony Ive keeps talking about.
I'm upgrading RAM and have removed all 8 screws but not touched the HD.
The bottom casing refuses to move and feels like there's something else
connected. No info in manual, any ideas?
We're inside!
Disassembling this laptop is reminiscent of the old PowerBook G4 Titanium models, and very similar to the MacBook Air.
You remove the bottom plate, and everything is screwed into the upper case. The case is now Apple's custom-machined unibody enclosure.
The interior is cleaner and flows together better than the previous Pro.
Cable routing from various parts of the case to the logic board is simpler in this than the new MacBook because Apple had more room to play with.
Removing the two 1 GB DIMMs. These chips are a new RAM type for Apple, 1066 MHz DDR3 SDRAM.
Apple claims this machine maxes out at 4GB RAM, but the Montevina chipset appears to support up to 8GB.
Shameless plug: You can upgrade your existing MacBook or MacBook Pro to 4 GB. We'll also be offering the RAM for the new Unibody machines in the near future.
Here's the complete spec on the memory module
Hi,
somebody already tried 8GB? I saw that the new 17" Unibody has an option for 8GB so I am wondering if it is also possible in the 15" Unibody Pro.
What are the exact specs of the memory module? Is it 1066 6-6-6 or 1066 7-7-7 or the slowest one 1066 8-8-8?
Thanks for the info.
Citaat van xanthalas:
Hi,
The original 15" Unibody does not support 8 GB, but later 15" Unibodies do.
Citaat van miro:
Hi miro.
Thanks for your info. How comes? What changed in the models? Starting with which Model of the 15" MacBook Pro 8GB is supported? The one without ExpressCard Slot but with Cardreader or also older models of the 15" MacBook Pro. How can I identifiy if 8GB are supported or not?
looking forward hearing your answer soon.
Hi miro.
Nobody knows?
The timing of the memory would also be interesting (CL).
Thanks
We're going to remove the optical drive next.
Disconnect these two connectors.
Citaat van notu:
The little ribbon being pried is the optical drive; is the other one the airport/bluetooth/iSight cable? I need to disable these things and am looking for the easiest way to do it. I don't yet have a new 15" Macbook Pro because I need to find out before I order it.
You are correct. The upper cable is what Apple calls the 'camera cable' (leads to the display) and the lower one is the optical drive cable.
Citaat van notu:
Does the same cable also connect to the Bluetooth and WiFi?
Yes, the cable connects to the camera, AirPort card, and Bluetooth card.
"disconnect those cables"...duh ! HOW ? the "camera cable" does not exactly look like your standard cable insert... how the @^%% do you disconnect this one without breaking it ?
Citaat van demerdland:
Pull the connector toward the optical drive, parallel to the face of the logic board. This page is a teardown, and should not be used for disassembly. Check out our MacBook Pro 15" Unibody page for detailed repair instructions.
Boy, DO NOT disrespect that cable. My BT went out and then when I played with it too much my airport went out. Was scared, but pushing it gently around got it working. Don't pull UP on this cable at all, pull to the left.
The optical drive is SATA for the first time. Panasonic model #UJ878A.
The superdrive in the last model was ATA, model #UJ857.
You can see the different connectors in the middle picture. The new, SATA connector is on top.
The rightmost photo is a shot of the new drive label.
Pry the two fan connectors up off their sockets on the logic board.
Remove the following 6 screws:
Three 3.1 mm Philips screws.
Three 3.7 mm Philips screws.
Citaat van elmancho:
How do you disconect the connector ?
Pull up, or sideways (towards the fan) ?
Ty :)
I went ahead and edited the step to make it more clear. Thanks for pointing it out!
I actually found it easier to remove the screws first and ease out the fan before lifting up on the connector to remove it.
Logic board bottom.
Some of these:
CY8C24794-24L is a SoC with a lot of bus interfaces, a LOT of analog interfaces and CapSense touch capabilities. This chip is very versatile and function cannot be determined by it's typenumber. It might run fanspeed, touchpad, backlight, temp. sensors and lot of other functions I cannot even think up at the moment.
RTL8251CA is the 10M/100M/1G bit ethernet chip.
H5RS5223CFA are the GDDR3 videomemory chips.
ISL6236 is the power supply controller.
Here are the two Nvidia chips! They occupy a significant amount of the logic board. There's no way both of these puppies could fit in a MacBook Air.
The first chip is marked 37N3C2 0836B2 PB6623.S03 MCP79MXT-B2. This is the GeForce 9400M, also serving as a northbridge.
The second chip is marked U807B034 0827C1 NH7962.01W G96-632-C1. This is the GeForce 9600M GT, which has 32 processor cores and is capable of 120 Gigaflops.
Continuing the disassembly, we're going to remove the display assembly.
Remove six 6 mm T-6 Torx screws near the hinge.
There are also two small hinge parts on top of these six screws that need to be taken off. Big step missing here. Disassembling the hinges and separating the display from lower case is complicated procedure that needs more pictures/directions.
Citaat van Rolf:
The absolutely crucial step that's missing at step 24 is that you need to open the display by 90 degrees before unscrewing the hinge from the main body!!
As it says in the intro, this page is a teardown and should not be used for disassembly. Check out our MacBook Pro 15" Unibody Late 2008 and Early 2009 device page for detailed repair instructions.
Removing the lower display bezel.
Help!! How does one get from Step 24 to Step 25 and separate the display from the bottom case? Seems to be a lot of info missing here.
To remove the cover you need to slide it to the left about .5" to release it.
Removing the Airport card.
Disconnect the antenna connector and the data cable.
Remove the two screws.
The Bluetooth cable disappears into the display, and our sources tell us that it's sandwiched between the glass and the metal case. This means that if your Bluetooth goes out, you may have to replace the entire display!
Airport card (the pink is a thermal pad).
The "unibody" upper case assembly.
This case assembly includes the keyboard, glass trackpad, and ribbon cables.
While the manufacturing of the case is sexy, our sources say that Apple is treating this as a single replaceable part. This means that if you break a key on the keyboard, you'll have to replace the entire upper case. That could get very expensive.
Hello, Is the picture of the lower case assembly is the one that we can buy "as is" on your store ? I mean, nothing missing? I've to change the upper case of my MBP and I'd like to now if I can go to the step 28 and go backward from step 28 to step 1 with my new upper case. Thank you!
Does anybody know what type of LEDs are used there?
What are the foam things called on the edge of the case above the keyboard?
The sliver foam pads are called EMI gaskets. They are used to extend the EMI shielding across a gap between two other conductive surfaces or to lessen the leakage of EMI noise outwards.
Dan -
In an attempt to save a lot of people a lot of money, we're going to try removing the keyboard from the upper case.
The keyboard is secured by lots of tiny black Phillips #000 screws. We're removing ALL of them.
Hi to all.
I wanted to know if the keyboard was also 13,3 removable by the 56 targeted or if it was welded into a store because I have said it was welded.
Thank you for your reply.
OK, we got them all out. There are 56 screws on the keyboard, plus two on the power button.
This is looking promising!
We got it off! Phew. It took about 15 minutes to remove all the screws.
It looks like users may be able to repair their own keyboards after all! Great news for the heavy-handed and spill-prone.
Hi can you get replacement keyboards? What is the part number on the keyboard? are all new 15" keyboards the same?
is there any website that sell only the backlid keyboard for the macbook pro?
Citaat van vaughnescobal:
is there any website that sell only the backlid keyboard for the MacBook Pro?
I was unable to find one and ended up replacing the entire case. BTW, I had gone this route before shopping for the replacement -got the backlight panel off and removed all 56 of those screws. I even removed all the keys (using toothpicks and a hemostat), but found the membrane sandwich under the metal frame laminated together. Other than harvesting keys for replacement on another kybd, there's no point breaking it down any further than shown here.
It's a shame, too, cuz a factory new lower case ends up being $250-$280 depending on the source. The kybd alone should've only been about $50.
Wow! What an incredible machine. We are very impressed by the ease with which the new MacBook Pro came apart. This machine should be a joy to work on.
Bottom left: hard drive and battery.
Top: Display
Center: Logic board, fans, and speakers
Bottom-center: subwoofer, optical drive, RAM, and heatsinks.
Right: Custom-machined unibody upper case and keyboard.
Here's a high resolution image.
Looking for more pictures? We've also disassembled the new MacBook.
i was just wondering: is there anyway to incorporate the keyboard of the previous gen mbp into this one? (maybe some 3rd party product) i loved the way the keys were curved on the mbp and this ones arent. Just wondering.
Citaat van suburbiansam:
The two keyboards are not compatible, unfortunately. We are not aware of a way to rig the MBP 15" Al keyboard into the MBP 15" Unibody.
Citaat van miro:
thanks anyway miro. I'll keep brainstorming a way to combine the power of the unibody with the comfort of the mbp.
Wow great site! Top of my list!
Say I spilled beer on the keyboard (for the sake of the argument :)
Apparently, some LEDs have dimmed but don't seem to be off (line going from the F2 to the "v" and everything to its left). I do not know if it's electrical or I can fix it by sweeping something. What's your guess?
Citaat van amonras:
If you're lucky it's some kind of shortcut in the wires. You'd cleanse the keyboard using calcium free water (buy some at your local garage), wash the beer stains off of the keyboard layers and let them dry. Be sure there is no water between the filaments when reattaching the keyboard, you might cause even more severe shortcuts!!
Another possibility is that the beer corroded the wires, in this case you'll probably see the wires on the filaments turned from silverish to grey/black, in this case you need a replacement keyboard or just live with the current situation.
Citaat van Deonics:
Could you mention what the locations of the speakers and the subwoofer are in Macbook Pro?
Check out our Macbook Pro 15" Unibody page for detailed instructions. We have one guide for the left speaker and one guide for the subwoofer/right speaker (they are in the same housing).
Citaat van roadrunner:
How long would you let the keyboard dry for after washing it with the water?
7 opmerkingen
What is the reparability score on this one?
is it possible to replace the memory cage after a spring holder part broke? There are 4 screws but after I took them out it was taking too much pressure to attempt to undo it unless I knew it was supposed to and which way it was supposed to go, Forward, Backward or up? Seems stupid to have to replace the whole logic board just to replace the plastic spring memory holder
I remember when I decide to remove the keyboard for my 2009 13" macbook pro "only for fun" hahaha
so what is the teardown score for this machine? Macbook pro 2009 got 7, so this must be even higher with user swappable battery and hard disk. So at least an 8 or probably even a 9 (but not 10 due to labor required to swap keyboard)? Best macbook pro ever from repair-ability stand point, which Apple is unlikely to ever match again.
We posted this before we started doing repairability assessments, but I’d reckon you’re right and this machine would be around an 8.
