Ga door naar hoofdinhoud
Deze demontage is aan de gang – Herlaad regelmatig om de laatste wijzigingen te zien!
Gereedschappen die in deze demontage worden gebruikt
Aanbevolen document
  1. Shut down the computer and disconnect the power cord and any other cables connected to the computer
    • Shut down the computer and disconnect the power cord and any other cables connected to the computer
    • Place the computer face down
    • Slide both battery latches away and lift the battery out
  2. Remove the three screws from the memory door Remove the door as shown Remove the memory cards by carefully spreading the tabs away from the card
    • Remove the three screws from the memory door
    • Remove the door as shown
    • Remove the memory cards by carefully spreading the tabs away from the card
    • Pull the card straight back and out
  3. Remove the six screws on the bottom and the two in the battery bay Remove the four screws from the side and two on the back Remove the four screws from the side and two on the back
    • Remove the six screws on the bottom and the two in the battery bay
    • Remove the four screws from the side and two on the back
  4. Open the display slightly past 90 degrees and use a spudger to loosen the top case A snapping noise is normal Do not lift the top case once it is free
    • Open the display slightly past 90 degrees and use a spudger to loosen the top case
    • A snapping noise is normal
    • Do not lift the top case once it is free
    • Slowly lift the top case until you can see the ribbon cable, carefully unplug then lift the top case off
  5. Remove two antenna connectors. Lift straight up Remove one screw and bracket. The card should rise up slightly
    • Remove two antenna connectors. Lift straight up
    • Remove one screw and bracket. The card should rise up slightly
    • Pull the card straight out
Bijgevoegde documenten
Luke
1.512 Reputatie
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 851
