Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Dual USB Connector te repareren, gebruik onze reparatiehandleidingen.
  1. MSI Dual USB Port Bracket Teardown, MSI Dual USB Port Bracket Teardown: stap 1, afbeelding 1 van 1
    • This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
    • These connectors plug into the USB headers on the motherboard.
  2. MSI Dual USB Port Bracket Teardown: stap 2, afbeelding 1 van 2 MSI Dual USB Port Bracket Teardown: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Phillips #1 Screwdriver
    $5.49
    Koop
    • Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
    • On the bottom of the circuit board, the pins that hold its components can cut skin.
    • The two USB 2.0 ports.
    • The four LED lights, which light up depending on the activity of the USB ports.
  3. MSI Dual USB Port Bracket Teardown: stap 3, afbeelding 1 van 1
    • Raise the three connectors from the case and it's out!
    • The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
    • The two USB ports.
    • The LED activity lights.
samhnri
415 Reputatie
2 handleidingen geschreven
Één opmerking
Why does it need its owe usb header just for the LED's.
Rick Acker - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 20
Altijd: 7,781
