Gereedschappen die in deze demontage worden gebruikt
Video overzicht
Inleiding
How to completely disassemble your tablet.
__________Video tutorial:__________
Deze demontage is geen reparatiehandleiding. Om je Lenovo Ideatab A1000 te repareren, gebruik onze reparatiehandleidingen.
  1. Unscrew the two Phillips screws under the memory card and the SIM card covers. Use a plastic tool and remove the back cover. Use a plastic tool and remove the back cover.
    • Unscrew the two Phillips screws under the memory card and the SIM card covers.
    • Use a plastic tool and remove the back cover.
  2. Unscrew the 8x screws and remove the mother board cover. Disconnect the battery connector. Disconnect the battery connector.
    • Unscrew the 8x screws and remove the mother board cover.
    • Disconnect the battery connector.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Volume Buttons, Power Button and Vibration motor Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector. Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
    • Volume Buttons, Power Button and Vibration motor
    • Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector.
    • Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
  5. Remove the lower speaker and the microphone. Unstuck the Power button, Volume buttons and Vibration motor from the middle frame. Unhook the LCD Display and the Touch screen flex cables.
    • Remove the lower speaker and the microphone.
    • Unstuck the Power button, Volume buttons and Vibration motor from the middle frame.
    • Unhook the LCD Display and the Touch screen flex cables.
    • 2x Phillips screws securing the main board.
  6. Remove the Logic board. Be careful, the mother board is sticked to the front outer case. Be careful, the mother board is sticked to the front outer case.
    • Remove the Logic board.
    • Be careful, the mother board is sticked to the front outer case.
  7. CPU - Mediatek, MT8317ATA Memory chip -  eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410 Power management chip - Mediatek MT6329BA
    • CPU - Mediatek, MT8317ATA
    • Memory chip - eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410
    • Power management chip - Mediatek MT6329BA
    • That's all.
ZFix
162.527 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
280 Leden
783 handleidingen geschreven
my mini usb track to board is damaged, can i repair it or can i know from where i can buy the PCB board for Lenovo Idea tab a1000
Jidendran S - Antwoord
Thanks for this guide!
Pooshon Banerjee - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 8
Afgelopen 30 Dagen: 40
Altijd: 12,718
